      10-29-2012, 10:21 PM   #1
BEAMERBOI
Photographer
BEAMERBOI's Avatar
Drives: x1 35i M version 2013
Yikes My tires are rubbing!!!
My Tires are rubbing the front right tire is. I just noticed it today while in reverse backing out of a parking spot. It rubs a bolt that in inside the finder.
Yes I have 15mm spacers on the front but this should not affect the wheel from front to back.
Has anyone who has 19" wheels with M package have this problem?
Again I have plenty of space when tires are going straight it only when I turn the tires in towards the left very sharp this happens. see pic to demonstrate.
Again this in only on the right front wheel. the other side is close but not touching. but is almost by a thread....
The pics load vertical when loaded to forum????
      10-29-2012, 10:36 PM   #2
stonex1
stonex1's Avatar
Drives: 13' X1, 02' Chev S10
I'm a newb to BMW, but don't most front fenders/bumbers have a slight give away when hit? Maybe your right side just needs to be pulled out a few mm's.
Happened on my truck once, my buddy accidently backed into my front bumper and pushed it in a few inches. I just pried it back with a shovel.
Of course, you should go to the dealer, and not go for the shovel.
      10-29-2012, 10:48 PM   #3
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
The diagonal of a turned wheel is longer than the rectangle of a straight wheel. Just where the corners of the diagonal end up is affected by spacers - in your case, it appears that it lines up with the bolt, where it otherwise would be inside the bolt.
That said, there should be more clearance than this - imagine doing a turn on a bumpy road.
      10-29-2012, 11:53 PM   #4
TYC
TYC's Avatar
Drives: 2015 M235i TE
Loose the spacers up front, keep them in the rear. Also what size are your front tires, BMW recommends 225 width up front on a 19" with sport.
      10-30-2012, 03:46 AM   #5
aznpxdd
China
Drives: 2009 Audi A4 2.0T, 2012 BMW X1
Location: Dongguan, China / Taipei, Taiwan / Los Angeles
Send a message via AIM to aznpxdd Send a message via MSN to aznpxdd
I asked you in another thread, but you never answered, what offset are your wheels now with the spacers?
I'm currently running 19x8" ET25 with 235 rubbers all around dropped on H&R springs. I don't have this issue at all.
Life's a bitch and then ya die, that's why we get high, cause you'll never know when you gonna go!
      10-30-2012, 09:40 AM   #6
Grovsnus
Flight Lieutenant ≛
Normally, I'm not a grammar nazi, but in this case, it's quite important that he doesn't loose them but lose them. The former could be catastrophic.
      10-30-2012, 10:01 AM   #7
jraymond
Drives: 135i SGM
is this the stock setup or has anything been changed?
      10-30-2012, 10:23 AM   #8
BEAMERBOI
Photographer
BEAMERBOI's Avatar
dont laugh but how would I know how to find the off set?
      10-30-2012, 10:25 AM   #9
BEAMERBOI
Photographer
BEAMERBOI's Avatar
just 15mm spacers but 15mm going out will not add to the girth of the tire to cause this as spacers push the tire outward not forward. It would clear if not for the head of the bolt. its not like this on the left wheel no bolt to rub, Yes everything is stock minus the spacers
      10-30-2012, 01:25 PM   #10
stonex1
stonex1's Avatar
Have you tried throwing a wrench on the bolt to see if its loose?
Tightening might suck the whole assembly out of the way.
      10-30-2012, 05:00 PM   #11
Endless Details
Drives: 2015 328i Touring F31 Xdrive M
It's probably due to the inner curvature of the wheel well... When pushing the wheel out with the spacer it changes where the tire lands at full cut and everywhere in between. You can try removing the bolt completely and see if the liner is rigid enough to stay put which will give you 3-4mm of clearance.
You could also replace hex head bolt with a Torx head screw with same thread pitch which will give you 2-3mm clearance.
I haven't removed the front liners yet but if that hex bolt goes into a bracket it could be slightly off from the factory and you can adjust/tweak it forward.
Hope that helps a little
