      10-29-2012, 01:56 PM   #1
Peter16
Peter16's Avatar
Drives: BMW 320i Xdrive Msport
Seat Wear
My X1 has done less than 10,000 miles yet the driver's seat backrest is showing signs of wear.
As I only wear 'normal' clothing and not jeans with studs and rivets I'm a bit disappointed
Has anyone else had a similar problem?
      10-30-2012, 05:01 AM   #2
Jossen
Jossen's Avatar
Drives: X1 to come...
That's a shame!!! Must come from trousers or something you wore for the first time without washing or so...
Must mean that going with fabric isn't all that. I ordered leather though, easiest to clean, but I bet Alcantara is even worse to keep clean...
      10-30-2012, 09:09 AM   #3
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
Tried a portable steam cleaner?
      10-30-2012, 09:12 AM   #4
Peter16
Peter16's Avatar
Unfortunately the problem isn't that the upholstery is dirty, it's worn. It has dark patches because the red fibres have worn faster than the black ones
      10-30-2012, 09:36 AM   #5
Jossen
Jossen's Avatar
No one else facing this problem then?
      10-30-2012, 11:50 AM   #6
dchao
Drives: BMW X2 M35i
I'm not an expert in seating posture here.
But why is the rubbing happening in the lower back section of the seat?
Is that a sport seat you got there? A sport seat will give you a better lateral support so you won't be rolling around in you seat in the future.
For now, maybe adjusting your seating position will prevent rubber on that section in the future.
My 2 cents.
      10-30-2012, 01:03 PM   #7
Peter16
Peter16's Avatar
My 2 cents.
That could have something to do with the problem, it's a standard seat but with the optional lumbar support adjustment. It may be that it's concentrating most of the load over a small section of the backrest thereby increasing the wear. I'll reduce the amount of lumbar support and see if helps.
Thanks for your suggestions guys
