      02-07-2013, 09:01 AM   #199
CIWS
Moon Parasite
CIWS's Avatar
Drives: X1 35i Sport (was)X6 50i Dinan
Checked with Dinan again on the X1 as they were asking me customer questions and here's the rep's response.
"We are working on it and no shame for inquiring again! I wish I had some software or stuff here to sell you for it. I’m not sure when we will complete the software for either car. Have you signed up for the newsletter at our website? We can email you when we release stuff for the n55 and n20."
So they are working on both N20 and N55.
CIWS is offline   United_States
      02-07-2013, 01:27 PM   #200
BatManWins
BatManWins's Avatar
Drives: Le Mans Blue X1 35i M
expect around 50 hp more at least from cobb
http://www.cobbtuning.com/BMW-N55-Ac...wer-gains-135i
2013 BMW X1 35i "M"....ordered on Jan 13 2013 / received on Feb 19 2013
BatManWins is offline   United_States
      02-08-2013, 04:52 PM   #201
johanness
Hans X2
johanness's Avatar
Drives: 2008 Z4MC
Just ordered the BMS Stage 1 for our X1 (N20). I'll report back after. I went this route because the feedback has been stellar, and it's been installed in over 250 rides already. BMS is currently working on their Stage 2 for this (unlocking CAN features, more power, etc).
|Euro Headers|SS X-Pipe|REMUS|UUC|Zeck CDV|AFE Intake|H&R Springs|RPI Scoop|ZHP|AC Schnitzer Side Skirts|ESS DirectFlash|APEX|RE RaceBrace|
the very last TiAg Coupe
johanness is offline   Reply With Quote
      02-09-2013, 12:06 AM   #202
skylineguv
Drives: 2013 X1 35i M-Sport, Le Mans
Picked up my X1 specific KW V1 coilovers today and compared the part numbers with those of my wife's 335i xDrive setup. Front/Rear dampers and rear springs are all the same as the E90/E92 xDrive units. X1 specific items are sleeves fitted to the front dampers to suit the X1 front knuckle, and different front springs (10mm longer and slightly heavier gauge coil).
With this info at hand, and bearing in mind the relative lack of availability for the X1 specific units (KW NA will just say no, you can't have them), I'd say the E90/E92 xDrive items are a safe and workable alternative.
skylineguv is offline   Canada
      02-22-2013, 08:02 PM   #203
aob511
Drives: X1 35i, A4 1.9tdi
Can some one help me track down the mud flaps for my x1.. I cant find the x1 flaps.. any help is appreciated.. Thanks
aob511 is offline   Reply With Quote
      02-23-2013, 03:30 PM   #204
CIWS
Moon Parasite
CIWS's Avatar
Try this link
http://www.shopbmwusa.com/ProductLis...?CategoryId=13
      02-23-2013, 08:39 PM   #205
johanness
Hans X2
johanness's Avatar
Drives: 2008 Z4MC
I just finished installing the BMS Stage 1 piggyback in my wife's X1 (28i). It's the N20 (not N26) and thus utilized all 4 connections. Took about 45 minutes - easy. No CEL or anything. Only had to reset the clock and good to go.
First impressions: lots more pull. Neck-whipping acceleration in the higher rev-range. Seems very balanced, as you can meander around town with fuel economy in mind... then stomp on it and really feel the added hp/tq. I say well done to BMS.
Can't imagine what Stage 2 will look like
      02-24-2013, 08:19 PM   #206
nospam
Drives: X1 x28i; 128i; S2000
What's the production month/year? I believe all US N20 engines since July 2012 have the electronic wastegate like the N26, thus utilizing only 3 connections.
nospam is offline   Reply With Quote
      02-25-2013, 07:24 AM   #207
johanness
Hans X2
johanness's Avatar
Drives: 2008 Z4MC
a) Canadian X1 b) used all 4 connections - including the solenoid one under the engine cover labelled "1" on install.
      02-28-2013, 12:03 AM   #208
conceyted
conceyted's Avatar
Drives: 2013 X1
BMS N20 Stage 2 news: http://www.n54tech.com/forums/showthread.php?t=18786
TLDR: A new N20 2.0L world dyno record: 300+whp and 350+wtq!!! Stock everything except the JB4 N20 tune on E85 fuel.
conceyted is offline   Reply With Quote
      02-28-2013, 06:23 PM   #209
CIWS
Moon Parasite
CIWS's Avatar
But our engines are not supposed to be run on E85 fuel, so why post tune numbers using it ?
      02-28-2013, 09:34 PM   #210
conceyted
conceyted's Avatar
Drives: 2013 X1
If I had to guess, they are probably testing on E85 because lower octane brings more knock. I would rather them tune for the lowest octane they can find than for higher octane and be forced into 93 only (even though I only use 93 anyway)
      02-28-2013, 10:34 PM   #211
nospam
My understanding is that you can run E85 with the JB4 tunes.
      02-28-2013, 10:55 PM   #212
CIWS
Moon Parasite
CIWS's Avatar
Well cool, if he's remapped for e85 the turbos should love it.
      02-28-2013, 11:26 PM   #213
nospam
Looks like the JB4 autotuning supports E85 blended with 91/93 (straight E85 not recommended).
I'm glad I sold my N54 E90...too much temptation, power corrupts!
The N20 is saving me from myself.
I wonder which features will make their way into the N20/N26 Stage 2 (JB4) tune?
N55 Stage2 (JB4) Upgrade Kit
Upgrades your current Stage1 control box to the latest Stage2 JB4 processor. Featuring 5x the processing power, 2x the memory, more robust signal conditioning, and of course integrated CAN. The CAN module allows the Stage2 to communicate with your vehicle like never before. New features are too numerous to fully list but include code reading/deleting, optional in dash boost, timing, air/fuel, shift light, and IAT gauges, autotuning, a buttery smooth new CAN based integrated boost control system, steering wheel controls, built in downpipe fix, hot/cold oil temperature protection, progressive methanol integration, water pump remapping, and much more to come with simple firmware updates.
      03-01-2013, 08:54 PM   #214
CIWS
Moon Parasite
CIWS's Avatar
Any X1 35i owners out there using a JB Stage 1 ? If so did you use all 4 connectors with the install ?
Edit- Disregard, does not work no matter what config used.
      03-03-2013, 08:23 AM   #215
ACZakka325i
ACZakka325i's Avatar
Drives: X1 3.5 M-Sport
Are you saying JB4 Stage 1 is not compatible with the X1 35i?
I'm planning on a tune after breakin service and that is the one I was going to purchase.
2013 535i xdrive(Current)
2008 E92 M3 (Gone)
2006 E90 325i (Gone)
2002 E46 325xi (Gone)
1991 E30 325i (Gone)
ACZakka325i is offline   Reply With Quote
      03-03-2013, 08:29 AM   #216
nospam
I'm pretty sure BMS N55 Stage 1 (JB3) and Stage 2 (JB4) are compatible with the X1 and are installed by members of this forum
      03-03-2013, 08:41 AM   #217
nospam
It appears that only the pneumatic boost solenoid engines will be supported initially (connection #1), and not the electronic. I believe this eliminates all US X1s from the alpha/beta. Hopefully the electronic solenoid is supported in the final release.
      03-03-2013, 10:35 AM   #218
CIWS
Moon Parasite
CIWS's Avatar
Negative. I have no experience with the JB4. I ordered and tried the JB Stage 1 harness. JB4 is supposed to be a different animal altogether inside.
      03-03-2013, 10:37 AM   #219
CIWS
Moon Parasite
CIWS's Avatar
I did post a question asking if anyone was running the JB stage 1, but no response. My question would be is there another owner running the Stage 1 harness on a 2013 35i ?
      03-03-2013, 01:27 PM   #220
Cfrem15
Cfrem15
Cfrem15's Avatar
Drives: E84 N55
Originally Posted by bmw5406spd View Post
what a difference, only 1k miles so after 5k should feel stronger, have BMS cold air install this weekend, also install down pipe when they get them instock again...
bmw5406speed has it on his 35i
Cfrem15 is offline   Lebanon
Forum Jump
