      02-24-2013, 09:43 AM   #89
rory breaker
Drives: C63
The 8sp shifts very quickly via the paddles. It's a terrific transmission. Very little delay. 6sp is slower but still not terrible...about on par with most 2008-2011 cars.
If you ordered a 35i you're getting the old 6sp, don't get your hopes up with dealer ineptitude.
      02-24-2013, 09:14 PM   #90
nospam
Drives: X1 x28i; 128i; S2000
Originally Posted by bosstones View Post
Question......how bad is the delay for manual shifting? By that, I mean how much lag is there between when you initiate a shift (down or up) and when the ECU/trans programming actually initiates the shift?
On the 8sp ZF there is practically no delay. It shifts faster than you could humanly shift with a MT (my other car is a Honda S2000), even multiple gears in a single shift (if your fingers are fast enough!). The 6sp on my 2009 128i (GM) & 335i (ZF) shifted much slower and only one gear at a time. However, some have reported the 6sp on the X1 35i is a newer ZF version and shifts faster than on my old E82/E9x.
If you want to manually shift, get the paddles. Manually shifting with the stalk is awkward in comparison IMHO (my parents don't have paddles in their 328i).
      02-24-2013, 10:16 PM   #91
bosstones
Drives: o_0
I would definitely end up with the paddles. Coming from MT in my snow car, I'd go nuts driving straight auto again.
What I'm curious about, though, is how bad is the car programming about actually executing the shifts the driver initiates in certain conditions. My last auto car was a 2001 325i and it would usually shift decently but, say, down shifting going into a turn would suffer long delays before an actual down shift occurred (after I initiated it)....like the car thinks too much. Outside of a money shift, I wouldn't expect delay. Is that the case?
      02-24-2013, 10:47 PM   #92
nospam
I had similar complaints on my E39 540i AT programming (no steptronic). My E46 was a manual. I was not fully happy with my 2009 335i. If I needed to down shift more than just one gear there was delay and hesitation at times. No such complaints with the new 8sp transmission. I can be cruising in 8th and triple click down to 5th in an instant. They say it can skip 5 gears at a time but I'm not that fast (I maybe went directly from 8 to 4 once while testing).
If you drive the car as if it is a manual, you will have no complaints. Since, I am used to driving manuals, instinctively I ease up on the throttle when I initiate shifts. The transmission does a great job of rev matching IMO. I have heard people complaining of surging when shifting and I believe these people are keeping a constant or even full throttle pressure when shifting.
If keeping constant/full throttle pressure, the transmission does best shifting on its own in my opinion and does a damn good job in Drive Sport mode.
      02-26-2013, 04:40 PM   #93
COOLGREANY
Drives: 2014 xDrive28i Cashmere Silver
I ordered a x28 (U.S. Spec) here in Germany on 8 Feb supposedly with the Cold Weather Package (heated steering wheel) and the paddle shifter option. I even had the dealer go double-check everything last week (fingers crossed).
      03-26-2013, 08:10 PM   #94
li21
Drives: X1
Im buying used so mine wont have paddles.
When I test drove a demo car with paddles I was blown away.
Having never owned a AT.. only MT.. I felt the fun in the paddles was enough to get me over missing MT..
I'm even thinking of retrofitting paddles in mine now..
      03-27-2013, 09:57 PM   #95
Mtpisgah
Drives: 2010 WRX & 2013 X1
Can you retro fit paddles to an X1? I sort of wanted them but couldn't find one with them unless I also took a lot of stuff I didn't want like nav.
      03-27-2013, 11:16 PM   #96
nospam
You should be able to just like the E9x and E82 but the dealer won't do it for you. I haven't seen anyone do it on the X1 yet.
      03-27-2013, 11:22 PM   #97
li21
Drives: X1
Ive seen the work thats involved in a REtrofit and its not pretty!
However, these claim to be plug and play
http://www.motivemods.com/BMWRetrofi...-p/mm-pa-2.htm
so it seems like you dont have to wire up to your shiftier and remove half the cabin to get to it..
The guy told me it works on e84
Still need to spend up to a $1000 on a new steering wheel and sifter paddles..
This is on my list of to do's...
Let me know if anyone does it!
EDIT: $937 I priced up for everything on their website.. without shipping...
Not too bad!
      03-27-2013, 11:30 PM   #98
Ex-One
Drives: Ex-One
Has anyone taken delivery of a 2014 yet and had the paddle shifter issue?
      03-28-2013, 01:23 AM   #99
nospam
Not too bad!
Good find!!
      03-28-2013, 01:11 PM   #100
COOLGREANY
By "issue" do you mean "none" (when there was supposed to be some) or is there a problem/issue with the paddle shifters?
      04-12-2013, 05:58 PM   #101
trevakun
trevakun's Avatar
Drives: X1x28'//M',//M5x2,X5//M,X3 35M
Today I talked to me dealer and he took it back and ordered me a new one, it had about 100 miles on it and i had accepted it, nice dealer! only 2 more months
(2014)
