The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > CODERS E90 E91 E92 E93 in UK
      06-12-2012, 06:28 AM   #1
makkan00
makkan00's Avatar
Drives: F83 and F36
Guys,
Can I kindly request all of you, who CAN code to put your name with your coverage areas here, so our forum fellow members can benefit from your coding abilities. About charges, I am sure that you will be charging nominal fees if to help forum members.
I will start with myself.
makkan00
can cover Essex, London, and West Kent.
I can do followings;
F and E series coding
Coding Remotely
If you have a coding cable and software ready and not sure what to do, I can code your car remotely. Done few cars in UK, Norway, and Thailand.
Flashing Modules
1- Alpina Transmission Flash for 335i
only if you have N54 engine and built is 03/07 and onward
(Feedback)
2- Alpina Engine Flash for 320D
only if its pre 03/07 with dpf
3- Security update on all 3 / 1 series (may extend to other series).
useful for 2005-2007 owners who are excluded from dealers list
4- ELV toruble shooting / Steering wheel lock error
(Feedback)
Retrofits / Major codings:
-LCI tail lights retrofitting coding
-Xenon Retrofitting coding (Example)
-Hi-Fi coding of BMW head unit / CCC / CIC
photos of pre and post hi-fi coding
(Feedback)
-FRM2/3 retrofitted to cars with FRM1
Feedback1 Feedback 2
-Registering new battery or change AH on the car to accommodate battery of different AH or change to AGM type.
-CIC DVD playing when driving (for test purpose and off road driving only)
-Dension Gateway / ipod kit coding
-L7 head unit coding to retrofit L7 amp
-Increase brightness of DRLs and Keep them constantly bright (no dimming on parking lights / dipped headlights)
- Heating Seats retrofit coding
- Retrofit Head unit with USB / BT / DAB (example)
Increase Security of your BMW
-Add Chirp sound on locking / unlocking
-Add Visual sign (signal light blinks one time) when you lock your car.
These two helps to make sure that you locked your car. Somebody may have a signal jammer and if you do not hear locking chrip sound or turning signal light going, that means somebody is in the vicinity.
-Increase volume of your OEM security Alarm
-Add High beam flashing with your security alarm (park the car directing your windows of home and if alarm triggered, it will flash high beams to your windows)
Other codings:
- Update maps of CIC
-Add digital speed on speedometer
-Add instant mpg on speedometer (M sports car only)
-Fog light on with welcome light
-Increase the tilt of passenger mirror when reversing
-Wipers return to starting position if car is turned off
-Delete rear number plate LED errors.
-Mirrors folded with key fob
-Windows down with key fob
-Windows not interrupted when doors are opened
-DRLs on all the time on pre-LCI car depending on your light module
-Fog light delete for performance bumper
-Disable seat belt reminder / chime
-Windows switch working for one minute after switching off your car
-Central locking / unlocking button functional without key in ignition
- Add panic alarm on your remote
- Brake Force Display
CIC / Navigation related
CIC retrofit on a car with standard radio / on a car with CCC
CIC with DAB retrofit
Flashing CIC / Combox to latest software
Combox / Bluetooth retrofit
$6FL retrofit with CIC
Hardware work done
Help with sound system installation (Example here)
(Example 2)
(Example 3)
Addition of media / TV / USB box to CCC
Alpine kit Retrofit
Fully electric / Heated seats with memory retrofit
Rear Parking sensors (PDC) retrofit
So to all other CODERS in UK, please submit your details here.
Thanks.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      06-12-2012, 07:41 AM   #2
Billyray911
Billyray911's Avatar
Venezuela
199
Drives: Blah
What a fantastic idea.Hopefully,we'll get some decent UK coverage
      06-12-2012, 09:07 AM   #3
Shane.
Shane.'s Avatar
Drives: F15 X5 40d M Sport
awesome idea. have you any pics of the white lights M3. will it work on a 2006 E90 320d. if yes how much you charge
      06-12-2012, 10:20 AM   #4
makkan00
makkan00's Avatar
Drives: F83 and F36
This Post is reserved to add information on coders. I will be updating it regularly.
DISCLAIMER: I take no responsibility of the work done by any of these. Please make sure that you check feedback of these traders. About forum members, some of them I know that they can code your car, and some I never met. So please make sure that whoever you choose, is up for the job.
1- Cambridgeshire region = Frobius forum member.
2- Hounslow = BW chiptune is authorised autologic dealer and bmw specialist (submitted by MEGA)
3- Surrey and surroundings = A- Meshyo Forum member, can cover surrey and south London.
B- AVC Uk Website (submitted by Hotcoupe)
C- Stourbridge Automotive LTD. Website (submitted by Billyray911)
4- Birmingham = Andy Website (submitted by Alpina 527)
5- Croydon = trinijay forum member.
6- Central Essex = Alpina 527 forum member, can do followings
LCi rears, flip mirrors on locking, wipers to rest after locking, Cic retrofit coding, Combox retrofit coding.
7 - North London = AlphaBravoCharlie forum member
8 - West London = afsar forum member
9- Newcastle upon Tyne = stevens forum member
10- Cornwall and some of Devon = johnboy98 forum member
PS: This list is updated regularly. If you do not have any coder in your region, please reply to this thread, as somebody may provide information on coders in your region.
      06-12-2012, 10:22 AM   #5
makkan00
makkan00's Avatar
Drives: F83 and F36
It can be done on your car. Photos here
PM is very handy for rest of details.
      06-12-2012, 10:46 AM   #6
AdrianSi
AdrianSi's Avatar
Drives: E90 330d LCi MSport
This is great as coding is becoming more and more useful even when just swapping parts. When my father swapped a faulty sunroof switch/module that had to be coded!
I shall be looking for hi-fi coding in the nearish future
Makkan ,being as you've being playing around with the audio sides of things, is there away to enable the L7 equaliser??? Or is this something that the L7 amp deals with? I'm guessing the latter
      06-12-2012, 01:32 PM   #7
makkan00
makkan00's Avatar
Drives: F83 and F36
I will look into this mate. I am sure that HU can be coded to L7 settings but you will require amplifier.
I will get back to you on this.
      06-12-2012, 04:20 PM   #8
ctch22
Drives: E90
vg idea makkan, have been meaning to pm you as I saw some of ur posts regarding coding lci tail lights retrofit. will pm you in a bit if that okay
      06-12-2012, 06:58 PM   #9
makkan00
makkan00's Avatar
Drives: F83 and F36
no worries mate.
      06-13-2012, 06:13 AM   #10
makkan00
makkan00's Avatar
Drives: F83 and F36
CODERS, can I kindly request you guys to submit your details here.
I am getting many pms where people want to get their cars coded out of my coverage area.
Kindly come forward and put your details here.
      06-13-2012, 07:11 AM   #11
jimpom23
Drives: 335i
Was going to post on here about my trusted indy investing in autologic recently based in West Yorks, just outside of Leeds - as far as I know there are no other places locally that have it
In terms of the specifics as per the OP, I'm not sure but if people were interested in finding out I could get some details from him.
      06-13-2012, 09:02 AM   #12
makkan00
makkan00's Avatar
Drives: F83 and F36
Jim, can you post some details of the garage and what they can do, that would be great.
I will add it up in my initial listing to facilitate this.
thanks.
      06-13-2012, 09:38 AM   #13
AdrianSi
AdrianSi's Avatar
Makkan - maybe if there is enough interest a 'coding' meet could be arranged if regional coverage doesn't look promising? Get a few members together to cover your fuel costs for coming out of area. Just a thought...
      06-13-2012, 09:44 AM   #14
MEGA
Dieseasal
MEGA's Avatar
Drives: LCI E92 335d M-Sport
Anywhere in London / Reading areas I'd say it's worth travelling to BW chiptune in Hounslow authorised autologic dealer and bmw specialist
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport
      06-13-2012, 10:33 AM   #15
Nigelo
Drives: E92 335i se
I was thinking that if someone already had the coding software and cable then Makkan might be able to remote access the laptop and code remotely.
      06-13-2012, 11:06 AM   #16
makkan00
makkan00's Avatar
Drives: F83 and F36
Good idea, but depends on interest of people.
On 24 June I will be in Walsall, if that is of any help to any fellow member.
      06-13-2012, 11:07 AM   #17
makkan00
makkan00's Avatar
Drives: F83 and F36
Thanks. Added to list.
      06-13-2012, 11:08 AM   #18
makkan00
makkan00's Avatar
Drives: F83 and F36
Good idea, but I guess I would have to improve my networking skills then
      06-13-2012, 12:00 PM   #19
Hotcoupe
Hotcoupe's Avatar
Drives: Don't know yet!
These Guys did the coding on the LCI rears + fold from fob w/mirrors on my car.
They can do most coding if it's on Autologic + other stuff too.
http://www.advancedvehiclecentre.co.uk/index.html
      06-13-2012, 12:07 PM   #20
makkan00
makkan00's Avatar
Drives: F83 and F36
Added to the list. Looking at their price list, I assume you paid
ECU Programming/Coding From £49.50 Plus Vat
      06-13-2012, 12:09 PM   #21
Hotcoupe
Hotcoupe's Avatar
Something around that figure,yes
      06-13-2012, 02:05 PM   #22
sparkie
sparkie's Avatar
Drives: E91 330i
Is there anyone in mid Scotland available for this?
There is a garage in Coatbridge just outside Glasgow have the Autologic equipment but they clearly don't know how to operate any of their stuff after mis diagnosing faults on my M5.
After five attempts, over a tank and half of fuel and a lot of wasted time I gave in with them and took it to BMW who told me exactly the problem. £100 though..
I won't be back to the 'indy' garage...
