      04-04-2012, 12:30 PM   #155
WiredRacing
Drives: 2012 X1 28i
Had them replaced a few months back. They were squeaking even worse after the change out.. but now that the weather has warmed up. It's gone.
Whatever. I didn't buy the car to impress other people. If this just means I get fresh brake pads every year to put up with a bit of noise I can't really otherwise hear when listening to music... horray! bring it on.
WiredRacing is offline   Reply With Quote
      05-07-2012, 11:41 AM   #156
hookah66
dirigir é a minha paixão
hookah66's Avatar
Drives: e93 328c N52 3.0L cabriolet
2002 325xi  [0.00]
2009 328i cabriolet  [0.00]
BMW OEM pads always squealed from my '98 e39 528i Touring, '02 326xi e46 to '09 328i e93 cabriolet, in addition to annoying dust brake. My solution? Replaced with aftermarket stuff, here in US, Aekebono Carbon's worked quite well for my '09 328i e93 cabriolet. You can get good high quality pads in addition to the OEM ATE, i.e. Pagid, EBC, etc.. You can do yourself, or use an independent but BMW certified mechanic. Thanks for letting me know that the yet to be introduced US X1 have brake squeal issues. You may also lessen the squeal by hosing the calipers with water. It is not harmful at all to the pads, the heat generated will dry them in not time. Sometimes the squeal is caused by improper "bedding" of the pad material on the rotors. Search on the web for proper "bed" procedures for new pad/calipers.
Sou fanático por conversíveis...
hookah66 is offline   United_States
      11-30-2012, 06:20 PM   #157
mrm83
Drives: x1
so the squeaking is back.. once it gets cold the squeaks come..
mrm83 is offline   Reply With Quote
      11-30-2012, 08:38 PM   #158
hookah66
hookah66's Avatar
2002 325xi  [0.00]
sorry to hear that... I have put something like 15K miles on my Akebono Cool ceramic pads and I got absolutely no squeaks whatsoever, and minimum dust.
      04-10-2013, 01:22 PM   #159
ohnoyuji
Drives: Mini Cooper/ BMW X1 i28
OH My God... people, my squeaking problem has been solve, but worst had came.
The new pads that BMW put in had made grooves all over my rotor!!!!
That's a bit more than 1 year since I've change them.....
Can you guys check your rotor and tell me if they look fine?
ohnoyuji is offline   Reply With Quote
      04-11-2013, 11:18 PM   #160
Grovsnus
Drives: Le Mans blue X1 35i
No squeaks, but boy, do I get the crunching fingernail-against-blackboard sounds if braking hard. It makes my teeth hurt.
I know better, but still imagine an asbestos cloud from each front wheel.
Grovsnus is offline   No_Country
Forum Jump
