      01-29-2012, 12:06 AM   #111
Phil777
Phil
Drives: 2010 550i GT, 2012 X1 28i
Originally Posted by mrm83 View Post
rotors too??? maybe this time it will actually be fixed!
I wish! I'm hoping the squeaking I heard tonight is an isolated incident, but I'll let you guys know over the next few days. Those two days of silent braking was sheer bliss...
Phil777 is offline   Canada
      01-30-2012, 08:49 AM   #112
WiredRacing
Drives: 2012 X1 28i
I'm not going to read the previous few pages since I last looked, but I've been meaning to update you guys for a while.
Had the car in a couple months ago for the 2 recalls a Check Engine light (my reader said it was an idle air solenoid if I remember correctly, but BMW said it was a fuel evap purge or something, and it was also in for the squeaking brakes.
Prior to taking it in, the brakes were only squeaking when they were cold.. after a bit of driving, it would go away. Now they seem to squeak just about anytime. I haven't bothered telling BMW yet, not interested in wasting my time until the spring, perhaps by then they'll have a proper fix (or maybe one is contained in the previous pages?).
WiredRacing is offline   Reply With Quote
      01-30-2012, 11:07 PM   #113
Phil777
Phil
Quick update on our squeaking brakes. I had the X1 out twice in the last two days - both times with multiple stops (and I always made sure they were easy/gradual stops, since that's when the brakes seemed to squeak the most). Not a peep out of them in the last two days. Perhaps the rotors and pads are starting to 'seat' properly. Here's hoping...
      01-31-2012, 12:30 AM   #114
DUH CAR
Originally Posted by DUH CAR View Post
What are the part numbers for this change? I'm trying to figure out what's the latest. Thanks.
Phil --What are the part numbers for this change? I'm trying to figure out what's the latest. Thanks.
His: 2007 E93 335i
Hers: 2012 E84 Deep Sea Blue xDrive28i with HK, CA, PDC, Nav+Prem+Conv+Light Pkgs
DUH CAR is offline   Canada
      02-01-2012, 10:00 PM   #115
zone555
zone555's Avatar
Drives: 2009 E90 335i xDrive
Just chiming in on this thread. Brake pads were changed twice with the following part numbers:
Nov 25, 2011
34-11-6-797-858
Jan 31, 2012
34-11-6-799-166
Maintainence was performed at Parkview BMW both times, and we did not specifically ask for the revised parts. So it seems they know what to do on their own
zone555 is offline   Canada
      02-01-2012, 10:53 PM   #116
mrm83
Drives: x1
Nov 25, 2011
34-11-6-797-858
Jan 31, 2012
34-11-6-799-166
looks like it's the same pad I got back in december..
I have had the 34-11-6-799-166 pads for 3000km now, still squeaking..
mrm83 is offline   Reply With Quote
      02-02-2012, 10:59 AM   #117
zone555
zone555's Avatar
What?? The 34-11-6-799-166 pads squeak too??
      02-02-2012, 11:40 AM   #118
DUH CAR
Yep. Heard a few little squeaks today when out and about.
His: 2007 E93 335i
      02-02-2012, 04:31 PM   #119
fdpxfunix
Drives: X1 sDrive 18d
Hi All
Just as a side comment... I've got a brand new 118i at the moment why my X1 is having some work done to it... and the front brakes on this car squeal a lot when braking at low speeds. I got the 118i with a 160 miles on the clock and it's now on 600 with the squealing getting louder.
I'll be glad to get the X1 back!
J.
fdpxfunix is offline   United Kingdom
      02-02-2012, 10:43 PM   #120
iwantanx
Drives: 2012 X1 xDrive28i
I had the brake pads replaced this week as well (34-11-6-799-166) and they still squeak, but I haven't driven very far with them yet.
I also had the 2 recall items performed: the PCU reprogramming and the turbo vacuum lines clamp replacement (16-13-1-379-229).
iwantanx is offline   Canada
      02-03-2012, 01:14 PM   #121
Phil777
Phil
Hey DC - just got the part numbers from the work order. Pads were the same as the first replacement - 8mm pads: 34-11-6-799-166. Rotors (21mm) part number: 34-11-6-854-999. We have been squeak-free for almost a week now - and I love the sound of silence when pulling up to a light! Perhaps replacing both the rotors and pads at the same time has allowed them to 'seat' properly, thus taking away any squeaking... Hope this helps!
      02-03-2012, 04:13 PM   #122
DUH CAR
Thanks Phil. I'll keep monitoring it as the squeaks are just every now and then. Replacing both makes some sense and might be the ultimate answer.
His: 2007 E93 335i
      02-06-2012, 08:22 AM   #123
jershu
Drives: x1
Can you tell me which dealer changed the rotor and pads , I can only get them to change the pads
thanks
jershu is offline   Reply With Quote
      02-06-2012, 10:43 PM   #124
Phil777
Phil
thanks
It was Parkview BMW in Toronto - excellent service! They replaced both the rotors and pads after first replacing the pads only (the squeaking was still there the first time). The squeaking has been gone now for over a week.
      02-07-2012, 09:30 AM   #125
dinamo
dinamo's Avatar
Drives: 2012 BMW X1 xDrive28i
Nov 25, 2011
34-11-6-797-858
Jan 31, 2012
34-11-6-799-166
My pads(no rotors) were replaced to 34-11-6-799-166 @ Calgary BMW back in December and I haven't had any squeaking at all ever since
2012 E84 Sapphire Black xDrive28i with Premium ,Comfort Access, PDC,Electrical Seat/Memory
dinamo is offline   Canada
      02-07-2012, 05:37 PM   #126
dieslengine4ever
dieslengine4ever's Avatar
Drives: BMW X1 23D Manual
Hi all, this may be an answer from 'good ol blighty'.
I took it in to the dealership as I noticed the car rolls an inch before the handbrake bites when I park on a small or large incline. I also noted that when there is a bit of moisture in the air and parked on an incline, it causes the pads to lock onto the discs. This happens before and after the working day. To move off I have to 'rock' the car in the opposite direction to the direction of intended travel in order to release the pads. If not locking, then a screeching can be heard for approx 500 feet. After that there is no noise. This also happened on my 320d. This time I wanted answers.
The explanation given by the service manager was that BMW use 'floating' brake discs. The purpose is to self tension. It is also quite normal.
'If' I understand correctly, this design needs to stay pretty close to the discs in order to brake as there is no spring mechanism to release. It may also reduce 'warping' from heat expansion under braking due to the floating mechanism. Please feel free for someone far more technical in brake design to expand or shoot me down on this.
It was also stated that to apply the handbrake correctly pull the lever ‘all’ the way up. Many other manufactures have a short travel especially Ford (UK). When people cross over to BMW they experience the car rolling away from them on inclines because they have applied 5 clicks rather than 'topping' off the handbrake travel.
It would appear the squeaky brakes is another BMW characteristic just like the infamous clutch judder, which it is advised to hold for 2-5 secs on the clutch (like burning it out)....
'I first realised Diesels had something to offer when my Ford ST200 couldn't out pace an Audi A3 2.0 140 BHP. Then I realised he was getting 20 MPG more than me!'
dieslengine4ever is offline   Reply With Quote
      02-08-2012, 07:51 AM   #127
DUH CAR
Interesting but we never use the handbrake.
His: 2007 E93 335i
      02-09-2012, 07:52 AM   #128
Phil777
Phil
Well, we knew it was too good to be true. The squeaking brakes returned yesterday after over a week and a half of beautiful braking silence - just a little squeaking at first, but now they're getting worse and worse again as we drove it last night. Back to the dealership. How annoying...
      02-09-2012, 08:15 AM   #129
DUH CAR
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
His: 2007 E93 335i
      02-09-2012, 07:06 PM   #130
mrm83
Drives: x1
this is ridiculous.. its been like half a year and still no fix. can't believe we paid for a defective car.
      02-09-2012, 07:18 PM   #131
Phil777
Phil
So weird - I took the X1 out today and did about 20 slow, easy stops - not a squeak, squeal or any other noise. What's going on?
      02-11-2012, 07:45 AM   #132
jershu
Drives: x1
Dealer finally changed rotors and pads .
its only been a day but so far no squeaks
Forum Jump
