      09-26-2011, 02:14 PM   #1
ohnoyuji
Drives: Mini Cooper/ BMW X1 i28
Winter Corrosion Harzard. Design Problem?
Last night, I opened the hood, looking at the Front Left wheelarch, I'm totally Shock with what I see there.
There are 3 open holes that are totally exposing outside contaminant going in the engine compartment!!!
These holes is right on the inside arch of the Front left wheel.
Each of these holes are 1 inch in diameter.
It looks like these holes are holding some kind of sensor.
In the harsh Quebec Winter environment and salt paved road, these three holes is definitely bad for corrosion!!
Has anyone find this is a bad design? or is it just me having this problem??
I'll try to take a picture, so you guys know where I'm talking about.
      09-28-2011, 01:28 AM   #2
R0ut3r
Drives: 2016 X6M and 2016 X1
BUMP ! Pictures please
      09-29-2011, 09:09 AM   #3
bacchaebabe
bacchaebabe's Avatar
Australia
Drives: BMW X1 xdrive23d
Interesting. I had the bonnet open a couple of weeks ago as my father in law likes looking at engines. I'd actually never bothered opening it before myself. But he noticed those holes immediately too.
He was more concerned about water and mud coming through from the wheel arch into the engine compartment but I'd done some driving in very heavy rain recently and the engine bay was spotless so it doesn't seem to be an issue.
Hadn't thought about corrosion but I don't live in an area where this is much of an issue. Plus there's the corrosion warranty anyway.
      10-03-2011, 11:53 AM   #4
ohnoyuji
Angry
Here is the picture....
I now realize the the Front Left wheel arch area has 3 1 inch diameter opening and you know what.
There is another 3 inch diameter hole on top of that!!
Take a look of yours and tell me what you think.
At first sight, it seems like that BMW are making these hole for the Right hand drive version, because on the Right side, there's some other sensor or plug that is occupying the same area, but for Right wheel arch..
I'm SHOCK>>>>>>
      10-05-2011, 08:34 AM   #5
DUH CAR
Sounds like a good use for some duct tape.
His: 2016 Jag F-Type 'S' Italian Racing Red
Hers: 2012 E84 Deep Sea Blue xDrive28i with HK, CA, PDC, Nav+Prem+Conv+Light Pkgs
      10-05-2011, 10:48 AM   #6
ohnoyuji
I think i will end up using some PRC to glue up this huge opening with stainless steel aviation duct tape.
I can't accept this flaw from bmw
      10-05-2011, 06:13 PM   #7
Edmom5
Australia
Drives: 2010 BMW E84 X1 Xdrive23d
I would love for someone from BMW to comment on the purpose of these holes... I noticed them as well on day 1 of my RHD purchase and wondered the same questions...
      10-06-2011, 04:05 AM   #8
ohnoyuji
where is your unplug holes are?
On the Right hand side?
      10-06-2011, 05:20 AM   #9
xspencex
Drives: BMW X1 18d
Yeah, that's a bit of a surprise, holes like this can exist in a chassis as they are often standardised across the range, but normally unused holes would be plugged.
Need to check mine when the wife gets back.
      10-06-2011, 06:10 AM   #10
Fliegenfranz
Fliegenfranz's Avatar
Germany
Drives: X1 x20dA
The german X1 forum found out:
These adaptors are for an ADDITIONAL WATER PUMP for the heating.
Do you remember, in earlier models bmw's climatic control panels had a "Rest-knob"...the engine has'nt to run and once activated these pump circulated the still warm cooling water through the heat exchanger.
It seems that there a configuration exists where that pump is still build in. I know from a xDrive 23D and a sDrive 18i.
On the part of BMW for these 3 holes is no solution in sight. So to prevent dirt to enter the engine bay, take duck tape and fix it.
(sorry for my bad english)
      10-06-2011, 07:43 AM   #11
Mulberry
Catuvellauni
Mulberry's Avatar
Drives: X1 xDrive23d MSport
Just checked my car for these holes, and to say that I'm unimpressed with BMW is an understatement. There is simply no excuse not to have a correctly designed blanking plate for these holes.
Another example of accountant cost cutting. Add this to the poor quality windscreen rubber seals that were 'fixed (bodged) with tape rather than changed, and 'iffy' quality interior door handles on a car that is meant to be a premium product that also produces very high margins of profit for BMW, and all I can say is "accountants 5 customers 0". Customer focus, joy? Hmmm.
Unless there is a free retro fit of a correctly desighed blanking plate for these holes, when I come to change my car BMW will have lost a customer.
      10-08-2011, 12:04 PM   #12
DUH CAR
Taped them up now from both sides. Will see how long it lasts.
      11-12-2011, 12:36 PM   #13
Blue Bottle
Blue Bottle's Avatar
Drives: X1 x Drive 2.0L D
OMG that's not good I will look for these and make a complaint when I pick mine up in Jan. you should not have to tape up a brand new car.......
      11-18-2011, 01:54 AM   #14
dylzsrt
Drives: 2012 BMW X1
Wow...saw your pics and that is 110% unacceptable.BMW...what is happening to you...I am in a state of shock on that one.I'd go berzerk if that was on my car...regardless of the brand.you guys need to make a giant stink on this one
      11-18-2011, 07:48 AM   #15
DUH CAR
Isn't it on your car too?
      11-20-2011, 04:51 PM   #16
Blue Bottle
anyone taken this issue up with BMW yet ?
