      07-19-2011, 04:39 AM   #1
rob_378
HongKongX1
Hong Kong
Drives: X1 sDrive18i SPORT
Ipod nano/classic compatibility with X1
I have both an ipod classic and a 6th generation ipod nano. Both are compatible and working fine using a no name 3.5mm - 3.5mm cable, however none of the tracks/info appears on the display.
Is it because i have the standard stereo system, or is it because i'm not using one of the BMW cables.. or is there another reason?
Apologies for starting a thread similar to many others on this forum, and many thanks in advance for any help.
      07-19-2011, 04:06 PM   #2
fdpxfunix
Drives: X1 sDrive 18d
Hi Rob_378
The 3.5 jack (AUX) connection is just for sound only. It's an analogue connection and nothing more.
To get the iPod info on the stereo you need the iPod connectivity pack and of course the iDrive system to control it.
Do you have the multimedia interface with a USB connection?
I'm sure someone else will be able to help further
J.
      07-19-2011, 06:05 PM   #3
rafaelfontoura
Drives: bmw x1 s drive 18
Hi
I have had the same problem because my x1 it's sdrive 18i with business radio. I asked to diferent BMW dealers in diferent countries about it. They reply to me that the s drive 18 i and business radio have not been compatible with USB. Then i have searched a lot to try a usb retrofit and nothing. My ipod works very well with AUX without wheel control.
      07-21-2011, 10:03 AM   #4
rob_378
HongKongX1
Hong Kong
Hi fdpxfunix,
I dont have the i drive system or any of the others you mentioned. I'll just have to make do as it is.. still better than nothing! THanks for the info.
Rafaelfontoura, thanks for the info also. Pls let me know if you find a solution.
