FORUMS
- 5
| 06-28-2011, 06:55 AM | #1 |
Administrator
Drives: 1M Join Date: Mar 2005
BMW X1 updated with new sDrive20d EfficientDynamics Edition
BIMMERPOST NEWSBMW X1 updated with new sDrive20d EfficientDynamics Edition The BMW X1, the very first and still the only premium vehicle in its segment, continues to extend its pioneering position in the field of fuel efficiency. In the autumn of 2011, the model diversity across the range of the compact all-rounder will be complemented by the BMW X1 sDrive20d EfficientDynamics Edition. This model, which was systematically designed to provide driving pleasure simultaneously combined with reduced fuel consumption and emission levels, is powered by a 120 kW/163 hp four-cylinder diesel engine featuring BMW TwinPower Turbo technology. With an average fuel consumption of 4.5 litres/100 km and a CO2 emission level of 119 grams per kilometre it achieves best marks for efficiency in a BMW X model. Furthermore, from the autumn of 2011, a newly developed four-cylinder petrol engine with BMW TwinPower Turbo technology will be available for the BMW X1. The 135 kW/184 hp power unit also sets new standards in the reduction of fuel consumption and CO2 emissions within its performance class, with values ranging from 7.1 litres and 165 grams for the BMW X1 sDrive20i and 7.7 litres (automatic: 7.6 litres) and 179 grams (177 grams) for the BMW X1 xDrive20i. The consistent deployment of highly efficient engines and BMW EfficientDynamics technology fitted as standard helps BMW X models also achieve brand-typical driving pleasure combined with exemplary fuel economy and low emission levels. The BMW X1’s outstanding efficiency is a fundamental part of its premium character, which is unique within the competitive environment and also underscored by high-class workmanship, elaborated functionality, a variable interior and numerous equipment features. The BMW X1 sDrive20d EfficientDynamics Edition raises the relation between sporty and athletic agility and fuel economy to a new level. Its 2-litre four-cylinder diesel engine, whose BMW TwinPower Turbo technology comprises a supercharging system with variable turbine geometry and Common Rail injection, generates a maximum output of 120 kW/163 hp between 3 250 und 4 200 rpm. Maximum torque of 380 Nm is available between 1 750 and 2 500 rpm. The engine has been optimised in detail in order to achieve an exceptionally high degree of efficiency. Special model-specific features include a centrifugal force pendulum in the dual-mass flywheel, which compensates vibration experienced at low engine speeds, thus providing more riding comfort when the vehicle is driven within the economic low engine speed range. The gear-shift point indicator fitted as standard has been adapted to suit the new engine characteristics. Moreover, standard features also include brake energy regeneration, Auto Start Stop function, electromechanical power steering, a disengageable air-conditioning compressor and tyres with reduced rolling resistance. The BMW X1 sDrive20d EfficientDynamics Edition also features a longer rear axle drive ratio and specific light alloys in the Streamline design. Furthermore, the BMW X1 sDrive20d EfficientDynamics Edition features newly conceived insulation technology for reducing engine noise that is perceptible inside the vehicle. The noise optimisation measures will be deployed as from the autumn of 2011 in all further diesel versions of the BMW X1. The petrol engine variants of the BMW X1 also present themselves as pacesetters for ever-increasing driving pleasure combined with optimised efficiency. The BMW X1 xDrive28i is now being followed by further models featuring a new generation of four-cylinder combustion engines with BMW TwinPower Turbo technology. The technology package featured on the 2-litre four-cylinder power unit for the BMW X1 sDrive20i with rear-wheel drive and the BMW X1 xDrive20i with intelligent four-wheel drive comprises a supercharging system according to the Twin Scroll principle, the direct injection system High Precision Injection and variable valve control VALVETRONIC. This combination guarantees not only spontaneous response and sporty power delivery even in the higher load ranges, but also favourable fuel consumption that is outstanding for petrol engines in this performance class. Maximum power output of the new engine is 135 kW/184 hp, which is made available between 5 000 and 6 250 rpm, whilst maximum torque of 270 Nm is achieved between 1 250 and 4 500 rpm. Thanks to its supreme pulling power and sporting performance, the BMW X1 sDrive20i accelerates from 0-100 km/h in 7.4 seconds and the BMW X1 xDrive20i in 7.8 seconds. Average fuel consumption of 7.1 litres/100 km as per the EU test cycle and a CO2 emission level of 165 grams are applicable to the BMW X1 sDrive20i both in conjunction with the standard six-speed manual gearbox as well as with the optional eight-speed automatic transmission. The BMW X1 xDrive20i achieves an average fuel consumption of 7.7 litres/100 km (automatic: 7.6 litres) and a CO2 emission level of 179 (177) grams per kilometre. The standard BMW Efficient Dynamics technology package featured on both models comprises in addition to brake energy regeneration and on-demand control of ancillary components also the Auto Start Stop function and the gear-shift point indicator for vehicles with manual transmission as well as electromechanical power steering on the BMW X1 sDrive20i. With the introduction of the new engines, the drive portfolio of the BMW X1 will increase in the autumn of 2011 to a total of three petrol and four diesel power units with a power output spectrum ranging from 105 kW/143 hp to 180 kW/245 hp. All told, there is a choice of ten model variants, five of them featuring characteristic BMW power transmission to the rear wheels and five with the electronically controlled four-wheel drive system xDrive. The entry-level model from the BMW X family attains additional appeal through optimisation of the suspension technology as well as an extended range of optional equipment. The standard stability control feature DSC (Dynamic Stability Control) has been supplemented on the rear-wheel drive diesel models by the dry braking and fading compensation functions. The models BMW X1 sDrive20i, BMW X1 sDrive28i, BMW X1 xDrive20i, BMW X1 xDrive28i and BMW X1 xDrive20d are equipped in addition with the brake stand-by function and a hill-start assistant. The BMW Individual roof rail system High Gloss Shadow Line will also be available in future as an individual option and thus not only in conjunction with the M Sport Package for the BMW X1. Moreover, the optional range of BMW ConnectedDrive features will be supplemented as from the autumn of 2011 by the Real-Time Traffic Information function. Share this story
The new beast. BMW M5.
| 06-28-2011, 08:08 AM | #2 |
Another useful vehicle that we can't buy in the States due to insane EPA/California regulations.
See my photography at http://ronscubadiver.wordpress.com
| 06-28-2011, 09:31 AM | #4 |
Moderator
Um... am I missing something here?
If I am reading this correctly, the big (huge?) news here is that BMW has developed a *supercharged* gasoline 2L motor. Is that not what it says here? The new RWD diesel X1 model is great and all, but as far as relevancy to the community goes, I would say the supercharged 4 cyl is *huge* news. No? This means that we could very well see more supercharged motors from BMW in the near future, perhaps even 6 cyl and 8 cyl.
2008 Interlagos Blue E93 M3 - M-DCT
2011 Salsa Red Jetta TDI Sportwagen - DSG ![]() |
| 06-28-2011, 03:25 PM | #7 | |
| 06-28-2011, 04:31 PM | #8 |
I doubt it, but it'll be a good DIY.
His: 2007 E93 335i
Hers: 2012 E84 Deep Sea Blue xDrive28i with HK, CA, PDC, Nav+Prem+Conv+Light Pkgs |
| 06-28-2011, 08:07 PM | #9 |
No Doubt!
Joy
| 06-28-2011, 08:50 PM | #10 |
I saw an X1 at the BMW Welt last month when I picked up my car and I must say that it looks better in person than it does in photos. I sat in it and the ergonomics were pretty good for a SUV/crossover/wagon thingy. Not for me, but my wife might want one.
'11 BMW 335i (Alpine White) M-Sport, Premium, Heated Seats, HK, Ipod adaptor, dealer-installed PPK - Euro Delivery 5/11/2011
'05 Lotus Elise (Arctic Silver) Sport, HT, Stage II, Odyssey PC925 '87 Nissan Pickup (Burgandy) King Cab, 80k miles '13 Audi A3 TDI (Ibis White) Cold Weather Package, Bluetooth - Wife's car - Delivery 9/12 |
| 06-29-2011, 06:24 AM | #11 | |
Moderator
Either way, adding this information to what we already know from the Z4, 1 series, and other prior information, we finally have the complete picture (or at least close to it, I imagine) of the four cylinder gasoline engine lineup. 136hp N13B16 = *16i 170hp N13B16 = *18i 184hp N20B20 = *20i 201hp N20B20 = *25i 240hp N20B20 = *28i Obviously these are not set in stone, but this is roughly how it will probably go across all lineups. In other words, we can probably expect a 120i soon with this same new lower ouput N20 going into the X1, and we can likely expect the existing X1 sDrive18i soon to get the 170hp 1.6L motor. Of course, the outputs might not be exactly the same across models but they should be close.
| 06-29-2011, 08:54 AM | #12 | |
p.s. And possibly *23i. |
| 06-29-2011, 09:51 AM | #13 |
Moderator
Yeah, I hear ya. I had seen it quoted as 201hp before too. Like I say, they'll probably vary slighly depending on which vehicle they are in (not to mention, by region). And yes, I do agree we may see some *23i too, though it may use the same power level as in the *20i or *25i, because I don't think we will see a *20i, *23i, and *25i version of the same vehicle all sold in the same region (though you never know).
| 06-29-2011, 11:48 AM | #14 | |
Drives: BMW 520d Join Date: Mar 2011
Originally, a supercharger meant any air compressor used for forced induction. When the air compressor uses exhaust gas to spin it, it is called a turbosupercharger, this was later shortened to turbocharger. |
| Bookmarks |
