      12-17-2010, 03:58 AM   #1
manicm
Drives: X1 sDrive18i
Underfloor tray
Is it safe to remove the underfloor tray and just use the normal cover? This makes the boot usefully deeper.
The normal cover seems quite hard and robust.
      12-17-2010, 04:05 AM   #2
Gatekeeper
Gatekeeper's Avatar
France
11
Drives: BMW 320d Security
Unless you plan on carrying concrete blocks in the trunk, there should be no problem. Just keep in mind there is a bettery on the right bottom hand side.
"Let our manners distinguish us from our enemies, as much as the cause we are engaged in"
      12-17-2010, 09:49 AM   #3
nathan35
Drives: X1 sDrive18d
I had the same preoccupation lately, and I'm still a little worried that heavy luggage may damage the battery and wiring at the bottom the trunk. Anybody knows if it's possible to find somewhere a rigid underfloor tray, as opposed to the soft one which is mounted in the car?
      12-17-2010, 12:38 PM   #4
Gatekeeper
Gatekeeper's Avatar
France
11
Doubt you'll find such a specific device aftermarket. Check with your BMW Dealer for an OEM one.
In my opinion you are going thru a lot of trouble to gain an inch or so...
      12-17-2010, 02:56 PM   #5
manicm
Hmmm you're probably right, best left alone.
      12-18-2010, 02:47 AM   #6
Gatekeeper
Gatekeeper's Avatar
France
11
Aaaaab-so-lutely ! :d
