11-28-2019, 02:17 PM | #1 |
Rep 2,232
MHD Ecu unlock, software only!
MHD did it those crazy brilliant bastards. I haven't reviewed all the details but there is a software unlock for late model E series now!
I'm beyond excited. I'll be flashing this weekend when I get home and can review the needed steps. |
11-29-2019, 05:04 PM | #4 |
Rep 2,232
Flashed stage one. Love it. Eventually will install downpipe and intercooler and go stage 2+.
hooligan_G016430.00 |
12-02-2019, 07:06 AM | #5 |
Space Shuttle Door Gunner
6430
Rep 5,312
12-02-2019, 05:22 PM | #6 |
Rep 2,232
Correct. Or the MHD WiFi adapter will work. I had the cable laying around.
12-04-2019, 10:50 AM | #7 |
Rep 562
If it gets flashed back to stock is it detectable that it was once not stock?
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
12-04-2019, 06:15 PM | #8 |
Rep 2,232
12-12-2019, 09:37 AM | #9 |
Rep 568
I flashed mine a few days ago after seeing this thread. THANK YOU! Moved on from the Dinan stage 2 flash. I am running MHD stage 2+ but with my stock DP. I checked with MHD and since I am otherwise FBO and not tracking the car I'm good to go. The power is awesome! Car is overall running smooth but in some situations it feels like it is still adapting. What's everyone else running and how's been your experience?
12-12-2019, 04:38 PM | #10 | |
Rep 2,232
12-12-2019, 07:00 PM | #11 | |
Rep 568
I know exactly what you mean. I actually reached out to them about it. I’ll share their feedback with the group.
12-21-2019, 02:36 PM | #12 |
Rep 64
This software-only DME unlock for late e-chassis n55 has been great. How nice it is to not have to remove the intake manifold, remove the DME, spend $100+ and wait a week for a bench flash, then re-assemble everything.
I've used a JB4 on the X1 for a few years, so I'm now running one of the free BMS back-end flashes (the "pump bef") with the JB4. Definitely much smoother power delivery. Not sure if its any faster, though. I've not encountered the low throttle issues others are reporting with the MHD off the shelf maps. |
12-21-2019, 02:44 PM | #13 | |
Rep 2,232
12-27-2019, 01:22 AM | #14 | |
Rep 83
2013 MG X1 x35i M Sport
01-04-2020, 10:00 AM | #15 |
Rep 2,232
I flashed it again. This time I did NOT use linear throttle mapping. I only did a quick test and it seems much better than when I did it last time with linear throttle. Not perfect but usable at least.
It's pouring rain and 50 degrees out and I'm on snow tires so no logs today. Hopefully tomorrow I'll get to take several and send to MHD and Twisted. |
01-06-2020, 09:39 AM | #16 |
Rep 13
Waiting for spring to pull the trigger, hopefully by then they will have resolved the throttle issue.
In for updates |
01-06-2020, 11:22 AM | #17 |
Rep 2,232
01-24-2020, 09:44 AM | #19 |
Rep 568
Here is the data logging MHD needs in order to improve the tune. I'm unable to do so at the moment because of traveling but if anyone wants to help out the group feel free to send them your logs.
For the logs i need you to do the following: ****DSC Completely turned off for all logging**** 1. normal driving acceleration from a dead stop up to cruising speed and cuise for like 20-30 seconds. 2. 3rd and a 4th gear WOT pull from 2800-3000rpms start point up to about 6500rpms 3. a third gear shifting into 4th gear WOT pull. starting in 3rd gear around 3500rpms or so. once in 4th hold WOT for about 3-4 seconds and let off. (this checks post shift timing recovery). Please include the following parameters in yours logs: Accel Ped. Pos. Boost Boost target Boost Target Ex Fuel mode Gear IAT Lambda bank 1 LTFT MAF Oil temp Rail pressure mean RPM STFT 1 Throttle Position Timing Cyl. 1 Torque act. clutch Torque Limit 1-3 Boost setpoint factor Cyl1 Timing Cor Cyl2 Timing Cor Cyl3 Timing Cor Cyl4 Timing Cor Cyl5 Timing Cor Cyl6 Timing Cor Load actual Load req MAF req. WGDC WGDC After PID WGDC base WGDC |
darkrom189.50 hooligan_G016430.00 |
03-14-2020, 01:06 PM | #20 |
Rep 2,232
The new update has 1.6 maps and the weird throttle issue seems to be totally resolved in my car so far. Will continue testing but really nice update. I encourage everyone to try it.
03-19-2020, 02:26 PM | #21 |
Rep 568
Does idle feel normal with the update? Throttle and idle were both off with the previous one for me. Thanks
03-20-2020, 05:27 AM | #22 | ||
Rep 2,232
Yes it feels normal with power increases now. No more throttle issues at least on my car it's resolved. |
RoWoX3M401.00 |
