      06-05-2015, 02:31 AM   #1
Shock96
That was a hell of a thing...
22
Drives: 2013 xDrive 35i M Sport
Fitting square 255/40-18
Ok, so I am still searching for leather M Sport seats....meanwhile...
I am thinking the 255/40-18 size tire all the way around is a nice way to go for my rig.
Slightly taller than the 225/45-18 on there now. Willtheyfit.com shows them to be an easy fit (well theoretically).
Any idea on the best 8.5" wide wheel offset? 30? 35? 25?
I am looking at the new TSW Bathurst in 18x8.5 with +35.
Fairly light and rotary forged. Whaddya think? Gimme some opinions!
Last edited by Shock96; 06-05-2015 at 02:32 AM.. Reason: Broke my own huge image rule...
      06-05-2015, 05:55 AM   #2
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I don't know what fits there, but why don't you put 255/35r18 all around.
If you have fitment issues that would be slightly lower, lighter, fit easier, and gear down slightly.
Yeah, your speedo will be even 4 more % off, but get a scan guage to view exact speed.
      06-05-2015, 08:14 AM   #3
PrematureApex
255/40 is a stock size (225/45F, 255/40R), and basically the same diameter as a 225/45. Currently, I have 255/40s in the rear with a 15mm spacer on 9" 40ET wheels from my E46 M3. So that puts it around a 25mm offset. I don't think you'd want to go much less in that department, as you'll start to stick a bit too far outside the fenders.
A 35 series would be fine as well, and as mentioned, would help gearing... but I wouldn't for a couple of reasons:
1. The ride comfort/wheel protection will be that much worse, and
2. The fenders of this car are huge. A 255/35 is going to fill in the massive spaces even less.
I'd buy 35ET wheels, and use spacers to fine tune the fit to your liking.
245/40 or 245/45 wouldn't be an awful way to go either.
      06-05-2015, 09:58 AM   #4
Shock96
22
0w40X1 - Thanks for the advice, but that is way to low a profile for me. I have a degenerative neurological disorder so I am looking for some decent ride.
PM - Thanks for the specs you are running. Glad to hear they fit OK on the rear, but any ideas on the front?
      06-05-2015, 10:05 AM   #5
0w40X1
PrematureApex,
I appreciate you being more respectful of other people's ideas (mine) on this thread.
1. People that bought the 8 x19 and 9 x19 wheel package with M Sport run flat tires will have a much harsher ride than going to 40 and 35 profile on non run flat.
2. After talking down to my ideas, you're worried about fender clearance too big?
The OP will have to be careful with the front wheel setup he gets to not rub when turning. When changing things that improve feel and performance, I'm thinking I don't care if fenders don't look Donk. Less is more as in less weight and more performance, but to each his own. Lowering might be an idea, but If my car is handling good I'd not put untested springs on for looks; only if the suspension worked better.
      06-05-2015, 10:10 AM   #6
Shock96
22
Also, I forgot to mention I will be putting on a set of H&R springs so there will be a drop.
      06-05-2015, 10:14 AM   #7
0w40X1
Shock96,
I'm 63 and got CMT muscular dystrophy so I can barely walk to the car, and I sure ain't gonna wrench much anymore except oil change.
So tell me exactly what specs your X1 has so we don't keep talking in circles.
My M Sport is firm suspension, the run flats in 225/45r18 and 255/40r18 are firm, and probably what's jarring on potholes, but I'm pretty sure Michelin PSS will be softer.On good pavement the ride is very good, and control excellent. There are so many ways to order a BMW that we all sound like the 5 blind men describing an elephant.
      06-05-2015, 10:17 AM   #8
PrematureApex
I test fit the fronts as well. No issues at all. There's a LOT of room up front on this car.
Guys runnng lowered with 285s...
http://e84.xbimmers.com/forums/showt...ncia+orange+X1
      06-05-2015, 10:18 AM   #9
0w40X1
Ok, I see X line which is regular suspension, and you probably got 225/45r18 no season tires, but still with run flat.
      06-05-2015, 10:21 AM   #10
PrematureApex
Originally Posted by 0w40X1 View Post
PrematureApex,
The whole motivating factor behind your 35 series suggestion was an unfounded concern with rubbing.
The car will fit 255/40s up front, VERY EASILY, even lowered. There is no reason to go with a 35 series, but for a gearing advantage. He retains his speedo accuracy, keeps more ride comfort, and doesn't further dwarf the small-looking wheels within the huge fenders (not that I care that much about looks, but it's a COMMON complaint about this car, from an aesthetic standpoint).
I'm not "talking down" to your ideas...but it just doesn't make a ton of sense. You're proposing a solution to something that isn't a problem.
      06-05-2015, 10:26 AM   #11
PrematureApex
That's a very slight drop, no worries there.
      06-05-2015, 10:28 AM   #12
0w40X1
So a soccer mom's grocery getter can be a pretty good track car after all.
      06-05-2015, 10:33 AM   #13
Shock96
22
Oh yeah, I forgot about Activ3's car. 285's are massive, but I guess with the car's weight being quite high it isn't out of the question.
Thanks for all the advice guys. I think the 255/40 is the way to go for me and I am glad to hear they should fit fine with the right offset.
I am still hunting for wheels so I can choose based on the offset and weight.
      06-05-2015, 10:36 AM   #14
0w40X1
We are just not communicating.
You keep jumping to conclusions on peoples motives.
The BMW speedo is already WRONG, so who cares what it says.
I get my Scanguage closer to my eyeball, and it's corrected to exact speed.
I want the lower profile as a free gearing down, and a way to chunk 5# per front tire.
The BMW wheel and tire on the front is very heavy like 50# or something, but I like them and can take 10% weight off for more performance for less.
      06-05-2015, 11:18 AM   #15
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I run 245-40/19 on 8.5/ET35 fronts now. Perfect fitment, non runflat. No issues. My choice for the back works fine, but I should have gone with the ET35 9.5", instead of ET20. (275-35/19)
      06-05-2015, 11:56 AM   #16
PrematureApex
Agree with all of that.
      06-05-2015, 12:52 PM   #17
Twix
Twix's Avatar
Drives: 2011 e91
If you can order separate offsets for front rear, do +27 ish front and you can probably do +12-15 in the rear. That will put the wheels pretty flush with the fenders.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      06-05-2015, 01:51 PM   #18
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Your rears@ ET20 will stick out 1" more than stock. (8.5x18) My combo sticks out 1.4" more than stock,(rears) and that's about 1/2" outside the fender line, which is something I'm not crazy about. If you get a square setup, the 8.5 ET35 will be tucked in the rears, compared to the fronts.
      06-05-2015, 02:29 PM   #19
PrematureApex
For the ability to rotate tires, and fine-tune fitment, I like the idea of square wheels and adding spacers, personally.
      06-05-2015, 04:29 PM   #20
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
This' pretty smart. That model wheel only comes in ET35 or 15, so the 35 all 'round seems to be a winner.
      06-05-2015, 05:19 PM   #21
Shock96
22
Ok, so that answers a lot for me. I want them to be flush all around and I would like to rotate all around rather than side to side. Having said that, as Zee said, they do come in +35 and +15 so that would be perfect without the spacers at all. I am a little leery of spacers. When we were racing Spec E, alot of the GT2 and 3 911 guys were running spacers with no ill affect so....
As for the wheels, I am not sold on them yet. I like them, but I am open to others.
If I do go with those, then leave the +35 alone in front and add a spacer to the rear. Twix recommended +12-15 so that means a 20mm spacer vs just buying +15 for the rear.
Thanks for the help guys. I know this topic has been beat to death, but it is hard to find info to match exactly the need.
      06-05-2015, 05:24 PM   #22
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
If I do go with those, then leave the +35 alone in front and add a spacer to the rear. Twix recommended +12-15 so that means a 20mm spacer. Does that sound right?
That size spacer (20mm) should set your tire out 1.2" That's a little outside of flush.
