08-29-2013, 07:37 AM | #23 |
Flight Lieutenant ≛
18
Rep 918
08-29-2013, 09:30 AM | #24 |
Rep 20
08-29-2013, 10:27 AM | #25 |
Flight Lieutenant ≛
18
Rep 918
08-29-2013, 11:33 AM | #26 | |
Rep 20
I should have been more clear - I have the 8-speed (on the 2.8) and it doesn't work while the car is moving. So the question is - is there a trick to get it into neutral on the 2.8 while the car is moving? |
08-29-2013, 12:27 PM | #27 |
Rep 29
It works fine on my 8-speed. Just push the stick forward (don't have to press the unlock button on the left of the stick) and it goes to N and pull it backward to go back to D. Nothing tricky.
08-29-2013, 01:41 PM | #28 |
Rep 671
Drives: '15 M4, '15 i3
What's with the shifting to "N" while moving??
2002 X5 3.0i/man.*
2006 330i/man./Arktis/Grau* 2001 525i/step./Schiefergrün/Sandbeige* 2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Dinan Stage 2 *retired |
08-29-2013, 01:51 PM | #29 |
Flight Lieutenant ≛
18
Rep 918
Fairly similar effect to pressing the clutch on a standard.
- It prevents engine braking, i.e. you can roll without losing speed. - On FWD/AWD vehicles, it improves steering in slippery conditions. - Gliding saves fuel. |
09-11-2013, 08:14 AM | #30 |
Rep 37
So through all of this conversation, it's still not clear to me that the OP's question was answered. I'm having the same issue with pulling into the garage, stopping, engaging park, and having to restart the engine via the start/stop button before depressing it again and holding to shut it off and turn off the electronics.
It sounds like the only way around this is to pull in, stop moving (engine turns off), engage park, remove foot from the brake (engine starts running), and then press start/stop. Either way it requires starting the engine again to stop the engine, which doesn't seem well thought out. Please tell me if I'm missing something... |
09-11-2013, 09:23 AM | #31 | |
Rep 399
It's my wife's daily driver so I'll have to ask her...however I think taking her foot of the brake after putting it in park "solved" her problem. But I don't know exactly what that means! She may experience the same as you have described. The couple of times I have driven it I have not had an issue with auto-off in the garage but I don't know what I do to make that happen.
Rob - rcw119
- 2016 F82 - 6MT - Sakhir Orange - 2014 E84 xDrive28i - Valencia Orange - 2008 E92 335i - 6MT - Sparkling Graphite (Retired) |
09-11-2013, 02:12 PM | #32 | |
Lucky13
211
Rep 1,762
09-13-2013, 03:15 PM | #33 |
Rep 37
Again, missing the point. If the car is stopped and put in park but the ASS has shut off the engine, pressing the start/stop button (for any length of time) only serves to re-start the engine.
After doing a bit of experimenting, it does seem that taking my foot off the break prior to pressring start/stop does function to turn off the electronics. So the process is: pull into garage and brake to a stop, ASS shuts off engine, engage park, apply parking brake, remove foot from brake pedal, press and hold start/stop. Quite the list just to shut off the car! |
09-13-2013, 04:07 PM | #34 |
Rep 675
Tell her to unfasten her seat belt. This will disable auto start the engine ;-)
Or push the park button on the gear selector pressing the break pedal. Like in the good old 6-speed tranny days. Last edited by d1saster; 09-13-2013 at 04:29 PM.. |
09-13-2013, 04:11 PM | #35 | |
Lucky13
211
Rep 1,762
