08-01-2020, 05:29 PM | #1 |
Rep 56
Drives: 2014 BMW X1 35I Ultimate
2014 X1 E 84 35I Belt squeal, Bearing noises belt area
Now i replaced all i dlers again, they seemed ok but fcp euro warranty exchange, and a fresh warranty belt which has less than 5000 miles on it, chirping when hot.
80k on car, used a stetescope to listen to bearings, Ac Clutch bearing is noisy and rough, light howling found a # 157382 AC Clutch bearing assembly ,reman ,pulley hub with bearing on ebay 63.00 now how to do this , first order part regroup and get a strap wrench to fit pulley to hold it YOU TUBE 7SEU pulley replacement video exact procedure i hope i can do this in chassis as uneven belt wear and belt chirps when hot annoying ac works fine cold bearing is on the edge@ 80 k and very noisy and not smooth. so it has not been a good day but next week will be better when new parts come. https://www.youtube.com/results?sear...ey+replacement Last edited by proteus290; 08-01-2020 at 07:14 PM.. |
