      01-25-2013, 11:58 AM   #1
mullini
Mullini
mullini's Avatar
Drives: 2017 i3 BEV
Nav advice please
Well I have read the manual on Nav a couple times now, but I don't think I am getting how to use this function to its best advantage. Never had Nav in a car before.
Here are my questions for some experienced Nav people who will do me the favor of not referring me back to the manual (see my first sentence):
1 - traffic info for daily commute: what's the best way to get this? Two major LA freeways are part of my commute. I can turn on "traffic info," but the screen is so clogged with detail I don't know what I am looking at. Also, that won't show me alerts for a problem 10 miles ahead on my commute, on a different freeway (unless I do a lot of scrolling and adjusting I shouldn't do while driving...). Yesterday I added my home and my office as destinations. Is this what I should do to get the best traffic info for my commute - turn on Guidance at the start of my work trip, coming or going?
2 - adding destinations: I ended up doing manual entry. I tried the interactive map and it couldn't identify my location exactly enough to enter the address as a destination. Any hints? I also tried to enter an address once using voice command and got so frustrated I gave up. I couldn't get it to register the street number, just the street and city. Advice there?
3 - any other hints/suggestions? What are some ways other drivers use Nav to make driving easier?
Thanks in advance for any helpful replies!
      01-25-2013, 12:32 PM   #2
nospam
Drives: 2015 Alpina B6; 430i; X5 40e
You need to activate "grey traffic map" to see traffic properly (Sigalert type view).
Don't waste time with the interactive map. Enter destinations manually with iDrive controller or voice. The C&D's video review of xDrive28i has a great example of how to use voice to enter a destination near the end.
      01-25-2013, 12:46 PM   #3
icemilkcoffee
Drives: Soon to be x1
The gray map does show the different colors for different severities. But the downside is you can't get POI's with the gray map for some reasons.
      01-25-2013, 12:56 PM   #4
vbbuilt
Drives: x28i
You can also view traffic obstructions in 3-D view: Small triangles along the planned route indicate route sections with traffic obstructions, depending on the map scale. The direction of the triangles indicates the direction of the obstruction. The traffic signs indicate the significance of the obstruction.
▷ Red traffic sign: the obstruction affects the planned route or direction.
▷ Grey traffic sign: the obstruction does not affect the planned route or direction.
Also, if you're following a planned route, the GPS will verbally tell you that your route is being re-calculated due to traffic. This is Semi-dynamic destination guidance. So read page 155 in your manual, tells you all about that.
Vince.
      01-25-2013, 01:44 PM   #5
mrnd23
Drives: BMW X1
Does the NAV has spoken street names? I mean local streets not just major highways and interstates.
      01-25-2013, 01:46 PM   #6
nospam
I don't think so, just freeway numbers.
Past: E36 325i, E39 540i, F46 323i (AA tuned), E82 3.0NA, E84/F30 N20 BMS Stage 1, E70 X5 N55, F06 N55
      01-25-2013, 05:52 PM   #7
mullini
Mullini
mullini's Avatar
Drives: 2017 i3 BEV
Thanks all. I had forgotten about the numerous available videos. Watching a couple of those has also helped me a lot. I did not know about the settings/grey option, for example. Thanks again...
