      09-30-2012, 04:20 PM   #1
Humble_Bear
Drives: 01 530i,10 Golf,11 Sorento V6
2.0T Engline Oil Capacity?
I looked on the digital manual and it was suppose to have the oil capacity but instead it was left blank. Anyone know the approximate oil amount needed for an oil change. There is no dipstick so I would like to be as close as possible.
      10-01-2012, 07:37 AM   #2
mabrahams
Drives: X1 M-Sport 28i
5 quarts. While there is no dipstick; there is still a way to check oil-levels in the cluster.
      10-01-2012, 12:17 PM   #3
Humble_Bear
Good, I'll just have to buy a 5q jug from Walmart.
      10-02-2012, 01:39 AM   #4
waltermus
Work in Process
waltermus's Avatar
Drives: F31
I called 2 dealerships in my area: one said 6.5L, the other said 7L. I did my own oil change and put in 6L and the onboard computer said full (removed ~5.7L while the computer said full). I read on the F30 forums that the computer has space for extra oil because the N20 is known to consume oil.
In any case, please let us know how much oil you're installing and make sure its LL-01 rated. Some good examples are Castrol Syntec 0W30 and Mobil 1 0w40. OEM BMW oil (from the dealership) is also great.
Oh and the filter should be a cartridge with a black end cap.
      10-02-2012, 02:15 AM   #5
Humble_Bear
Would Mobil 1 5w/30 work?
      10-02-2012, 04:06 AM   #6
dicker
dicker's Avatar
Drives: F80 6MT
It's a good oil, but it's not up to BMW's spec for their engines. Their 0w40 is however.
If you want to run 5w30 just run the BMW oil.
      10-02-2012, 07:50 AM   #7
mabrahams
That's interesting too. 5.7L = 6 quarts. I saw on another F30 forum it was 7 quarts. (or 6.6L).
Isn't the general rule of thumb, one quart per cylinder plus one?
I don't believe the oil level shows over-fill correct? I wouldn't want to use so much, because that would lead to break down of seals.
      06-30-2014, 11:39 PM   #8
FrozenInCND
Drives: 2014 BMW X1
oil pan drain plug torque
OK I know this is a old tread, but I still can't find a torque spec for the drain plug. Has anyone discovered this mysterious number? As for the oil capacity I have accesss to Alldata and it clames 5.5L, but no torque specs.
      07-01-2014, 07:56 AM   #9
Twix
Twix's Avatar
Drives: 2011 e91
Like all drain plugs I've dealt with, you should go hand tight then 1/4 turn. You just need to plug the hole, there's not much crank case pressure. I also bet BMW recommends the replacement of the drain plug at every change.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      07-01-2014, 06:41 PM   #10
elfhearse
CW5
elfhearse's Avatar
Drives: 14 x28iS/10 e91M/00 Z3MC
2014 BMW x28i  [0.00]
2010 328iT  [0.00]
FWIW, I added 5 1/2 quarts during my first oil change = FULL after oil level check.
(measured out ~ 5 quarts when I drained the factory fill)
CURRENT:
10 328iT ZMP-6spd, 00 Z3 MCoupe, 76 2002 stg.2 5 speed
PAST: 96 318ti Cali, 03 325Ci, 00 Z3 M Roadster, 99 Z3 2.8 Coupe, 14 X128i M-Sport14 Z4 28i Sport 6-spd
      07-02-2014, 02:57 AM   #11
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Oil Capacity and Torques for N20 Engine
Why don't you download ISTA D. You can manually select any vehicle and find all diagnostic and repair information.
The information below is for N20/N26 engines.
