      02-27-2018, 06:11 AM   #1
2quik
Drives: 2015 X1 Xdrive 28i
Service history question
Does anyone know what this is? Purchased a 2015 CPO and this was in the service history, but no clue what this is. Pic attached
      02-27-2018, 06:15 AM   #2
2quik
Sorry didnt attach the first time.
      02-27-2018, 08:02 AM   #3
kiloTHREE
Drives: '13 xDrive28i
That's pretty generic, I would guess maybe one of the rear support brackets that ties the suspension to the unibody in the rear.
      02-27-2018, 10:07 AM   #4
PrematureApex
Not generic at all.
While it doesn't mention the side, the tension strut is a front suspension arm. The rubber/hydraulic mount is the hydrobearing on the inboard side of the arm.
They commonly fail, in addition to shitting up the steering feel. Many of us replace with poly.
http://www.1addicts.com/forums/showthread.php?t=1236485
Edit, damn photobucket
The bushing in this one...
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      02-27-2018, 10:24 AM   #5
2quik
PrematureApex, thanks for the detailed answer. You are always helpful
      02-27-2018, 10:28 AM   #6
kiloTHREE
I just had my rear tension strut replaced due to damage.
33326777637
Tension Strut according to BMW which attaches to a rubber mount...
So yea, generic.
      02-27-2018, 10:32 AM   #7
PrematureApex
33326777637
So yea, generic.
What?
33326777637 is a diff/V brace (also called a tension rod/strut according to some sites)...which DOES NOT mount with rubber, let alone a hydraulic bushing. Not sure where you got that. It's most certainly hard-mounted.
There are no hydraulic bushings on the rear suspension arms of the car either.
Maybe it was generic to you, but anyone who knows these cars, or even late-model BMWs in general, would immediately know what was replaced.
      02-27-2018, 10:46 AM   #8
kiloTHREE
Attaches to the rear axle carrier via 33306782159 which is a rubber mount.
Yikes!!!!!
      02-27-2018, 10:51 AM   #9
PrematureApex
Yikes!!!!!
What???
That part number is to a front rubber subframe bushing. Pressed into the subframe for bolting it to the car.
https://parts.bmwofsouthatlanta.com/...306782159.html #2
The V-brace you posted gets HARD BOLTED, both inner and outer. There are no bushings.
      02-27-2018, 10:53 AM   #10
PrematureApex
The other "tip" would be that it says "tension/compression" strut. That 100000% indicates a front suspension arm (RWD uses a compression strut, AWD a tension strut).
The inner side of a front tension strut uses a rubber/hydraulic mount prone to failure. There is no other spot on the car that description would be referring to, period.
      02-27-2018, 11:12 AM   #11
kiloTHREE
Originally Posted by PrematureApex View Post
What a jackass...
      02-27-2018, 11:18 AM   #12
PrematureApex
It's certainly not the first time you argue ridiculous things clearly out of your element.
Sure, it's frustrating...and spreads bad info.
You'll be happy to know I received points (for "jackass", really?).
      02-27-2018, 11:28 AM   #13
kiloTHREE
What a jackass...
What a jackass...
      02-27-2018, 11:29 AM   #14
kiloTHREE
That's an even better signature, you're a goldmine today!
What a jackass...
