      03-26-2023, 12:42 PM   #1
tkellykbnc
Drives: BMW X1 35i M-sport
Coolant dump
2013 X1 35i runs great for days, then will suddenly show low coolant followed by about a dump of about a gallon of coolant. Let it cool, refill and doesn’t lose a drop for days, then happens again. All looks dry on top, and 2 different mechanics (including 1 with 30+ years of Bimmer repairs) can’t find the cause. Pressure tested multiple times and it doesn’t lose a drop. The have found several small leaks and repaired them (at this point the don’t even charge me). Still, can’t really drive an otherwise great little car, since I never know when it will happen again.
Any ideas.
TK
      04-19-2023, 05:22 AM   #2
BRK
Drives: BMW 428i F36
Possibly and only a possible- the thermostat. Causes a surge if it fails to open correctly- too much heat in the block and out comes the water.
Had a similar issue with a Toyota Prado. Intermittent fault but (finally) noticed the temp go high then low.
      05-29-2023, 12:10 PM   #3
gJesus_1911
gJesus_1911's Avatar
Drives: BMW X1 E84 N55
Did you ever find the root cause of the coolant dump issue?
      10-13-2023, 03:58 PM   #4
SharpAndCunning
Drives: 2014 X1 35i
Did you ever find out what was causing this?
      04-04-2024, 09:43 PM   #5
40_roll_bmw
Drives: x1 bmw
My car did this exact same thing the day I bought it. Dealer installed a new radiator and retuned it back to me. Happened again 20 minutes after. They replaced the radiator once again (two in a week) and so far I haven’t had this issue. But the exact same thing happened to me. It would run fine then all of a sudden it would dump all the coolant.
      04-07-2024, 03:13 PM   #6
gJesus_1911
For me it was the radiator plug I believe or you might be having issues with your transmission heat exchanger since I believe it only dumps it when it’s up to temperature.
      04-16-2024, 01:42 PM   #7
maxwmiller
Drives: 2013 X1 xDrive2.8i
A loose or broken hose clip is also to be suspected. Could be fine at ambient temperature but come undone at operating temp.
