      10-30-2013, 02:35 PM   #1
donsbabybeamer
Drives: 2014 x1
Change Tire Size ?
Can I change my 225/45/18 to 225/50/18 on the same 18 inch wheel on my 2014 X1 X-line with out creating any driving risks or voiding the warranty. I want to soften the ride.
      10-30-2013, 02:57 PM   #2
Red Bread
Drives: Smog machines
There's more variation in tire brand / model than you're likely to get by going to a slightly larger tire. Changing from PS2's to PSS's on my last car softened the sidewall significantly.
But provided you change all four at once, you shouldn't encounter any issues, but you are adding almost one full inch of diameter, so you might get some rubbing at full lock.
Note that by changing to the larger tire, you'll be lowering the reported speed by 3.2% which will slightly help with the over reported speed BMW's (and all cars, really) read. Most new cars read 3-5% high, so you'd be removing most of this buffer.
      10-30-2013, 04:07 PM   #3
0w40X1
Drives: 2014 BMW X1 s28i M Sport
Continental DW or DWS are soft tires and very light also.
I go lower profile and softer on every car I get.
      11-02-2013, 10:10 PM   #4
Twix
Twix's Avatar
Drives: 2011 e91
There won't be any rubbing with an extra inch of sidewall.
      11-04-2013, 08:09 AM   #5
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
It's about 7/16" of sidewall. Radius increases this much X 2 for diameter. Should be problem free.
And I figure about a 2mph increase in actual speed at 60 mph indicated...just a guess
      11-11-2013, 05:57 PM   #6
GTony
Australia
27
Drives: 2015 X3 F25 XDrive 28i M Sport
Hi donsbabybeamer,
Check out 1010tyres.com - Under TIRE & WHEEL TECH - Tire Size Calculator. They show a diameter variance of 3.4%. It is recommended you stay within 3% of the diameter of the original tire. I'm not mechanically minded so don't know what the other comments mean, eg. Can be done stock our after suspension changes.
