      10-30-2013, 12:09 AM   #1
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Coding for DRL/Parking Lights/Standing Lights
I went through the whole FRM3 module options for lighting control and found few. My problem is I can't differentiate which lights are which. Here are the options:
PARKL_FKT_MIT_POL -na PARKING LIGHTS WITH CORNER LEDS
PARKL_FKT_MIT_BL -na PARKING LIGHTS WITH BRAKE LIGHTS
PARKL_FKT_MIT_SL_1 -a PARKING LIGHTS WITH STANDING LIGHTS 1
PARKL_FKT_MIT_SL_2 -na PARKING LIGHTS WITH STANDING LIGHTS 2
PARKL_FKT_MIT_NSW -na PARKING LIGHTS WITH FRONT FOG LIGHTS
PARKL_FKT_MIT_BFD -a PARKING LIGHTS WITH BRAKE FORCE DISPLAY
PARKL_SL_1_GEDREHT -a Upside down?
SL_FKT_MIT_POL -na STANDING LIGHTS WITH CORNER LEDS
SL_FKT_MIT_BL -na STANDING LIGHTS WITH BRAKE LIGHTS
SL_FKT_MIT_SL_1 -a STANDING LIGHTS WITH STANDING LIGHTS 1
SL_FKT_MIT_SL_2 -na STANDING LIGHTS WITH STANDING LIGHTS 2
SL_FKT_MIT_NSW -na STANDING LIGHTS WITH FRONT FOG LIGHTS
SL_FKT_MIT_BFD -a STANDING LIGHTS WITH BRAKE FORCE DISPLAY
BREMSL_FKT_MIT_BL -na BRAKE FORCE DISPLAY WITH BRAKE LIGHTS
BREMSL_FKT_MIT_SL_1 -na BRAKE FORCE DISPLAY WITH STANDING LIGHTS 1
BREMSL_FKT_MIT_SL_2 -a BRAKE FORCE DISPLAY WITH STANDING LIGHTS 2
BREMSL_FKT_MIT_BFD -na BRAKE FORCE DISPLAY WITH BRAKE FORCE DISPLAY
BREMSL_FKT_MIT_NSL -na BRAKE FORCE DISPLAY WITH REAR FOG LIGHTS
DRL_TFL_MIT_BL -na DAYTIME RUNNING LIGHTS WITH BRAKE LIGHTS
DRL_TFL_MIT_SL_1 -a DAYTIME RUNNING LIGHTS WITH STANDING LIGHTS 1
DRL_TFL_MIT_SL_2 -na DAYTIME RUNNING LIGHTS WITH STANDING LIGHTS 2 lower tail lights Mini
DRL_TFL_MIT_KZL -na DAYTIME RUNNING LIGHTS WITH LICENSE PLATE LIGHTS
DRL_TFL_MIT_SML_3R -na DAYTIME RUNNING LIGHTS WITH SIDE MARKER LIGHTS <<Eyebrows?
DRL_TFL_MIT_BLK_V_GED -na DAYTIME RUNNING LIGHTS WITH FRONT TURN SIGNALS
DRL_TFL_MIT_NSW -na DAYTIME RUNNING LIGHTS WITH FRONT FOG LIGHTS
DRL_TFL_MIT_BFD_3R -na DAYTIME RUNNING LIGHTS WITH BRAKE FORCE DISPLAY
There's also a lot of options to control voltage to specific lights at specific lighting mode:
PWM_FL - PULSE-WIDTH MODULATION (PWM) CONTROL OF HIGH BEAMS
PWM_FL_FKT_DRL_3R - PULSE-WIDTH MODULATION (PWM) CONTROL OF HIGH BEAMS AS DAYTIME RUNNING LIGHTS
PWM_FL_BEI_BIXENON
PWM_FL_NSW_FKT_ABBLIEGEL - PULSE-WIDTH MODULATION (PWM) CONTROL OF CORNERING LIGHTS
PWM_AL - PULSE-WIDTH MODULATION (PWM) CONTROL OF LOW BEAMS
PWM_POL - PULSE-WIDTH MODULATION (PWM) CONTROL OF CORNER LEDS
PWM_POL_BEI_AKTIVEN_AL - amber LED w/ headlight? e90 LCI
PWM_POL_BEI_AKTIVEN_FL - amber LED w/ headlight? e90 LCI
PWM_NSW_3R - PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT FOG LIGHTS
PWM_NSW_FKT_TFL - PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT FOG LIGHTS AS DAYTIME RUNNING LIGHTS
PWM_NSW_FKT_PARKL - PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT FOG LIGHTS AS PARKING LIGHTS
PWM_FRA_V
PWM_FRA_V_FKT_SIDEMARKER
PWM_FRA_Z_AN_SML
PWM_FRA_H
PWM_BL_FKT_BL - PULSE-WIDTH MODULATION (PWM) CONTROL OF BRAKE LIGHTS AS BRAKE LIGHTS
PWM_BL_FKT_SL - PULSE-WIDTH MODULATION (PWM) CONTROL OF BRAKE LIGHTS AS STANDING LIGHTS
PWM_SL_1_FKT_SL_TFL Angel Eyes
PWM_SL_1_FKT_BL_TFL
PWM_SL_1_FKT_PARKL - PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT STANDING LIGHTS 1 AS PARKING LIGHTS
PWM_SL_2_FKT_SL - PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT STANDING LIGHTS 2 AS STANDING LIGHTS
PWM_SL_2_FKT_BL - PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT STANDING LIGHTS 2 AS BRAKE LIGHTS
PWM_KZL_3R - PULSE-WIDTH MODULATION (PWM) CONTROL OF LICENSE PLATE LIGHTS
PWM_NSL - PULSE-WIDTH MODULATION (PWM) CONTROL OF REAR FOG LIGHTS
PWM_NSL_FKT_SL - PULSE-WIDTH MODULATION (PWM) CONTROL OF REAR FOG LIGHTS AS STANDING LIGHTS
PWM_NSL_FKT_BFD - PULSE-WIDTH MODULATION (PWM) CONTROL OF REAR FOG LIGHTS AS BRAKE FORCE DISPLAY
PWM_RFS - PULSE-WIDTH MODULATION (PWM) CONTROL OF REVERSING LIGHTS
PWM_BFD_3R - PULSE-WIDTH MODULATION (PWM) CONTROL OF BRAKE FORCE DISPLAY
PWM_BFD_ERSETZT_SL_1 - PULSE-WIDTH MODULATION (PWM) CONTROL OF BRAKE FORCE DISPLAY REPLACING DEFECTIVE STANDING LIGHT 1
PWM_IB - PULSE-WIDTH MODULATION (PWM) CONTROL OF INTERIOR LIGHTS
PWM_VFB
PWM_BL_M - PULSE-WIDTH MODULATION (PWM) CONTROL OF THIRD BRAKE LIGHT
Someone has a clue what these exactly are?
There are:
Corner LEDs
SML Sidemarker Lights
SL_1 Standing Lights 1
SL_2 Standing Lights 2
Thanks
