      08-14-2023, 03:20 PM   #1
SharpAndCunning
Drives: 2014 X1 35i
Factory 17" Wheels on 35i
Will all the X1 factory wheel options from the US Spec 28i fit on the 35i?
Looking at buying a set from a guy but my factory tires are 225/45/18. I've seen a lot of aftermarket wheels people run for winter tires, but not a lot of factory ones.
I have seem 1 base model 35i, (no line) and it had 17" BMW wheels, but I don't know if that was factory or not.
The wheels I'm looking at are these :
https://www.autorimshop.com/17-oem-w...UaAnYXEALw_wcB
BUT not from this website, it's a local sale.
      08-16-2023, 11:36 PM   #2
p4ddY
Germany
Drives: E84 3.0l N52
https://e84.xbimmers.com/forums/show...8#post30061528
      08-18-2023, 10:35 AM   #3
SharpAndCunning
Drives: 2014 X1 35i
Originally Posted by p4ddY View Post
Thanks, I did see that, and it said, "should" fit. But I can't find anyone that actually did it and confirmed.
      08-21-2023, 05:13 PM   #4
sudermatt
Drives: 2015 X1 35M
I haven't pulled the trigger on anything yet. But I'm eagerly watching this thread.
2013 X1 SDrive 2.8 > 2015 X1 XDrive 28 SLine > 2015 XDrive 35 M
      08-24-2023, 08:31 AM   #5
DaviBrown
Drives: mustang 1969
Factory wheels for X1 28i should fit X1 35i, but confirm compatibility with a BMW dealer. Check tire size too.
      09-16-2023, 08:39 PM   #6
sudermatt
Drives: 2015 X1 35M
35 has bigger breaks, so do NOT assume all 28 wheels will fit.
      09-17-2023, 02:34 AM   #7
p4ddY
Germany
Depends on which 28i you are referring to. The 28i N52 has the same 348mm brake as the 35i N55 - so the 35i does NOT have bigger brakes. Just the 28i N20 has smaller brakes with 330mm.
      09-24-2023, 05:22 PM   #8
sudermatt
Drives: 2015 X1 35M
That....is good information. Thank you sir.
      10-09-2023, 08:02 PM   #9
jonah.stupar9@gmail.com
Drives: e36 328i Touring - X1 35i
2013 BMW X1 35i   [0.00]
1995 BMW 328i  [0.00]
Not exactly the same situation you’re in but I can confirm that the 17in e90 style 157 wheels fit on an x1 35i. Additionally I suggest running a 225/55/17 tire. It fits perfectly and my speedometer is only 1mph off where when I had 225/45/17s it was 4-5mph off. (Tire rack thinks it doesn’t fit for some reason though, not sure why)
      10-13-2023, 01:30 PM   #10
SharpAndCunning
Drives: 2014 X1 35i
Thanks for the update! I love the Valencia Orange. I have wished I had gotten the orange or blue so a long time.
