      06-20-2013, 02:57 PM   #1
1stone
Drives: 2013 Alpin Weiss X1 X-Drive28i
Will 16-inch wheels fit on the X1?
As the title says.. Getting ready to put together a winter set as early as now.. I have been researching about it and the internet says that 17 inch wheels are the minimum but I just need to make sure from the real X1 experts.. Let me know..
      06-24-2013, 04:37 PM   #2
Naambezet
Netherlands
11
Drives: BMW X1 sDrive 20i
Don't think it will fit, unless you remove those things behind the brakes (what are they for?)
      08-10-2015, 11:55 AM   #3
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Bump to this old thread, has anyone ever test-fit 16" wheels over the brakes?
-Matt
| Z4M Build Thread | @violetnites | flickr |
      08-11-2015, 03:34 AM   #4
GrantE83
GrantE83's Avatar
Drives: BMW X3 E83
16" wheels must look tiny! I think my 17's are to small. Surely you can pick up a cheap set of 17" BMW wheels..
      08-28-2015, 10:26 AM   #5
black-box
Drives: 2013 X1 xD35 (1998 M3 RIP)
I had one of the few sets of 16" wheels (mille miglia) that would clear the rotors on my E36 M3 (315mm front, 312mm rear). The xDrive35 rotors are 348/336mm. I'm seeing sizes of 330 or 312 front, 300 rear on the xDrive28 and 312/300 on the sDrive28 (via PelicanParts). So they may fit on some E84s. I would test-fit, but I need a new floor jack
      09-08-2015, 10:25 AM   #6
eugenelt
Drives: None yet
Just asked a local tire shop, they said 16" wheel will not clear.
However, they also said "anything that is taller or shorter will throw off your 4WD system", referring to my 215/60R16. Given that the actual circumference difference between 225/50R17 and those are about 1%, which I mentioned to them, I don't see how it would influence 4WD.
Basically I think they're making an uneducated guess, so I'm a little doubtful they've actually tried to fit 16" wheels to X1. Will ask my mechanic, I guess.
      09-08-2015, 10:39 AM   #7
Alfisti
Drives: 2008 Saab 9-3 Combi
17's are so cheap, why you want 16's is beyond me.
      09-08-2015, 11:12 AM   #8
eugenelt
Drives: None yet
Because a full set of 17" winter tires will cost around $1000, and I already have a set of good winters from my previous car?
      09-08-2015, 11:22 AM   #9
Alfisti
Sell the old ones and pick up a used set of winters on 17's. Done.
      09-08-2015, 11:24 AM   #10
PrematureApex
As a general rule, looks aside, you want to run the smallest wheels that will fit over the brakes. Less unsprung weight and/or reduced moment of inertia, cheaper wheels, cheaper tires, better ride (tire dependent) etc.
While certainly not for everyone, there are many more reasons to run the smallest wheels possible than there are to not.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      09-08-2015, 11:29 AM   #11
PrematureApex
As posted above, might depend on which size front rotor you have (I think we determined a couple weeks ago that there was a change to larger front rotors at some point). If they're 330s, a 16 is going to be tough, but if they're the 314s (or whatever the smaller one was), you might be OK. E90 328s with a 300mm rotor run 16s easily, and you'd only need 5-8mm of clearance.
I'd search on the E90 forums a bit more for insight.
The shop is wrong. You can run larger or smaller overall diameters front and rear with no affect at all on the AWD system.
More generally, IIRC, BMW's xdrive can also tolerate front/rear diameter differences, which not all systems can. But regardless of that, running the same (larger or smaller) size front and rear is 100% fine.
      09-08-2015, 11:32 AM   #12
eugenelt
Drives: None yet
Why would I want to go through a trouble of finding a buyer for my tires, then looking for another set of used tires with unknown history, if I can fit my tires, which I know are good?
      09-08-2015, 11:53 AM   #13
Alfisti
'Cos they don't fit and unless you're running a MASSIVE profile tyre the ABS and AWD is going to be all fucked up as the running circumference is going to be way off.
      09-08-2015, 12:05 PM   #14
eugenelt
Drives: None yet
"'Cos they don't fit" - we don't know that yet, do we? That's exactly the point of this thread.
"running circumference is going to be way off" - I mentioned this above. The circumference (of 225/50R17 vs 215/60R16) is different by about 1", or 1.1%. I don't think this qualifies as a "way off".
      09-08-2015, 12:12 PM   #15
PrematureApex
No, no they aren't. Stop talking out of your ass.
The only "negative" effect would be the speedo being off one way or the other (but who cares, the factory speedo is intentionally inaccurate anyway). His ABS/TC and AWD are 100% fine. All the tires are still the same diameter all around.
      09-08-2015, 07:25 PM   #16
Alfisti
OK fine I should have read other posts. You really wanna run that small a wheel and that much tyre, gonna look freaky, like it's 1981 or something.
      09-22-2015, 08:51 AM   #17
Aerospike
Drives: 2013 F20 M135i
Are you going to swap the tires from the wheels they're on to a set of 16" BMW wheels? Can't you try the wheels you have and go from there or do you know for sure they won't fit (small ID, wrong bolt pattern, etc...)?
      12-03-2019, 06:02 PM   #18
phantom7835
Professional Nostalgist
phantom7835's Avatar
886
Drives: 20 M2C, 92 Miata
Super necrobumping this to confirm that 16s do fit in the front of non-sport models
....but they don't fit on the rear, or the offset on these is wrong. Either way in the rear I'm hitting the suspension knuckle. Front clears fine though
2020 M2 Competition, Long Beach Blue, Exec, 6 Speed
2005 M3 Coupe, SMG, eventual S62 swap candidate
2013 X1 x28i, Valencia Orange, Premium, Cold Weather - N20 exploded
2002 325i/5, Tiag - sold
1998 M3/4/5, Cosmo - scrapped
1992 Miata, Brilliant Black, STS - on the island of misfit toys
      12-05-2019, 02:46 AM   #19
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
check on tire rack
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      12-10-2019, 12:10 AM   #20
djeieidhds
run it
Oman
Drives: dhudeuehhrhdhehee
16" wheels come standard on non M models.
      06-02-2021, 10:54 AM   #21
Collindabin
Drives: 2013 BMW 340i
Will not fit
Unfortunately 16" will not fit. I have tried.
17" is the minimum! www.wheelsnearme.ca has a good fitment guide for your reference
