      12-29-2021, 11:04 AM   #1
Kevlar74
Drives: 2012 X1
Battery
Hi
I believe my 2012 X1 Battery is failing.
Really slow cranks and sometimes won't even turn.
I know that new battery needs to be registered to car.
Have BlueDriver code reader and hopefully that can register new battery.
Anyone used BlueDriver to do this ?
Thanks
      01-03-2022, 08:42 AM   #2
orca4wd
Drives: X1, Z3M
Hi Kevlar74
If you stay with the same Ah battery as your current battery then you can get away with just registration. If you change battery type (AGM or Lead Acid) or Ah (80 or 90) then you will need to change coding in the CAS:KLASS_BATTERIE. I don't know anything about this Bluedrive code reader. I have not change my battery yet but plan to use the NCS Expert tool and in the process on gaining how-to instruction.
      03-06-2022, 05:31 PM   #3
Kevlar74
Drives: 2012 X1
So Picked up OEM battery from BMW $411 tax in CDN
Old battery was only holding 11v
New Battery reading over 12v
Car running 14v
BlueDriver did have battery Registration feature. Just had to update software on it.
Car starts instantly
      03-27-2022, 10:17 PM   #4
coptica
Drives: BMW X1 2012 28i (N20)
my 2012 x1 original battery lasted nearly 7 y.
      12-30-2022, 05:58 PM   #5
Teutonic
Teutonic's Avatar
On my 2012 lasted almost 9 years of Canadian winters. And when I replaced it, it was in excellent health, I was just affraid it was too old so bought a new one….
      01-05-2023, 09:47 PM   #6
Botlfed98
Drives: X1
what brand battery is most ppl going with?
      01-07-2023, 05:39 PM   #7
Botlfed98
Drives: X1
any idea if this would work: https://www.odysseybattery.com/produ...ttery-94r-850/
      01-27-2023, 10:39 PM   #8
Shock96
That was a hell of a thing...
22
Drives: 2013 xDrive 35i M Sport
I swapped the original battery in my 2013 this last September. Went with an Interstate AGM in the factory size. Works perfect.
