      03-26-2014, 04:22 AM   #1
Tossi
Denmark
9
Drives: F11 20d
new wheels, but which
I'm looking for a new set of summer wheels for my X1 23D right now it has 18" original BMW alu, but that is whey to small and generic But my problem is i dont really know what type of wheels i want and what will look amazing on the X1 and also how big and wide i can go, i have been thinking about 8,5x20 in front and 10x20 in the rear but not sure if 10x20 will fit in the back.
I have attached the 3 wheels i have kinda settled on right now and the style i like, but again is far from sure.... So any pictures and suggestions are more than welcome
2011 F11 520d
      03-26-2014, 05:59 AM   #2
Gort
Klaatu Barada Nikto
Gort's Avatar
Drives: 2017 X3-35i
If you go to Tirerack.com you can enter your vehicle info and browse dozens of styles of wheels - then see a picture of what they would look like on your vehicle. You can even make the vehicle the correct color. I found it pretty cool.
Even if you are unable to order from them, it is still a good tool to help you visualize what different styles look best to you. Good luck.
      03-26-2014, 07:04 AM   #3
Tossi
Denmark
9
Drives: F11 20d
Thanks will give that a try
2011 F11 520d
      03-26-2014, 07:42 AM   #4
Twix
Twix's Avatar
Drives: 2011 e91
Not sure a 10 in the rear will fit being a 20" diameter. You can make it fit by cutting and rolling etc. The widest I'd go with a wheel that tall would be 9.5. Check out some of the photo threads, lots of us have aftermarket wheels. Some required trimming, some didn't.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      03-26-2014, 12:52 PM   #5
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
Had Beyerns once. They sucked. Cast out of round and never could get them sorted. Avoid at all cost.
20" all for show and no go. Ride will be terrible and handling will likely suffer. Not to mention how easily they will bend on less than ideal road surface. I would not go past 19".
JMHO
      03-26-2014, 07:51 PM   #6
Black Flagged
Black Flagged's Avatar
Drives: M2C
I like the last one or number 3! Looks the best to me.
      03-27-2014, 07:04 AM   #7
Gort
Klaatu Barada Nikto
Gort's Avatar
Drives: 2017 X3-35i
Looking at the Beyern in the second photo, it actually has similarity to the style of the wheels that come on the X-Line.
      03-27-2014, 10:00 AM   #8
balljack
balljack's Avatar
Drives: M5 | X1 35i | Cayenne
I'll pick the first one.
      03-27-2014, 08:44 PM   #9
GTony
Australia
28
Drives: 2015 X3 F25 XDrive 28i M Sport
I also suggest tirerack in particular Bremmer Craft wheels which are similar to your 8 double spoke selection.
As for colour, the mind boggles. I prefer Chrome but they need really looking after eg. Proper cleaning products which the biggest downfall is what you wash the car with, a lot are not good for chrome. My next choice would be Hyper Silver that's it.
My standard setup - 17x7.5 c/w 225/50/17. I got from carid.com 18x7.5 chromes. Would have liked wider and only + is they come in 18x9 for back staggered fitting. Maybe later. Haven't put the 4x7.5's on yet. Also they were cheaper to get from USA including freight than buying here.
The main point is - Know exactly all your cars Specs. eg. Original Set Up - PCD - OFFSET - CENTREBORE. I had to order my wheels according to a 2013 X1 SDrive 28i when my X1 is a 2011.5 SDrive 20d. But it took a lot of questioning of BMW to know that a lot of the models are similar.
Keep us posted and Good Luck entering the Wheel Minefield.
      03-28-2014, 08:38 AM   #10
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
Personally, I wouldn't go with 20's for a number of reasons. Regarding wheel manufacturers, I recommend VMR's if you can get them. They offer of number of styles and finishes in Square or staggered fitments. They have an impressive gallery on their website, although it seems to be offline right now. Tell them what you're looking for and they'll get you dialed in.
http://velocitymotoring.com/wheels.html
      03-28-2014, 03:07 PM   #11
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
the first one for me what does it weigh
      03-28-2014, 03:26 PM   #12
squishy
Zimbabwe
153
Drives: 2014 Ford Mustang GT
Second one!
      04-16-2014, 03:58 AM   #13
Tossi
Denmark
9
Drives: F11 20d
After a ton of surfing and visting wheelshops I think that I close to deciding on a set of Tomason TN9 in 8,5x19 and 9,5x19
2011 F11 520d
      04-16-2014, 06:57 AM   #14
HBWT
HBWT's Avatar
11
Wow, that's a busy wheel...almost Alpinalike.
Glad I don't have to clean them and thankfully, BMW has changed to ceramic pad material.
They look Okay, BTW.
      04-16-2014, 11:25 AM   #15
atomic
Drives: 2016 x3 x-line white
Those look nice. You will have to post photos when you get them put on your X1.
      04-19-2014, 04:43 PM   #16
GTony
Australia
28
Hi Tossi,
Looks good. Similar style to your other choices but for me not overkill on sizing.
Width - Min.Tyre - Ideal - Max
8,5 225 235-245 255
9,5 245 255-265 275
Good luck with your fitments and installation. Lets know final outcome.
      04-21-2014, 06:47 AM   #17
Gort
Klaatu Barada Nikto
Gort's Avatar
Drives: 2017 X3-35i
That looks nice but also looks like a bugger to clean.
