08-10-2018, 11:09 AM | #1 |
Rep 7
Maintenance Schedule beyond Factory Maintenance
My 2014 E84 28i ran out of factory warranty and maintenance recently and I'm trying to put together a master schedule for maintenance so I know when to replace what and don't have to worry too much about it. I've got the basics covered based on the manual (oil, cabin/air filters, spark plugs, brake pads/fluid) but wanted to get input on some items not discussed in the manual.
At what mileage do you think these things below should be replaced? I'm using mileage instead of years/time since mine is a daily driver and mileage just seems to make more sense. I looked at Bavarian Autosport’s E91 schedule (https://www.bavauto.com/media/import...ages/e91mc.pdf) as a starting point, but they have a very conservative schedule (more $ for them from people buying parts). I can share the master schedule when it's finished too if anyone is interested.
08-10-2018, 11:57 AM | #2 |
Rep 98
I have attached the ZF transmission instruction from the manufacturer
according to the manufacturer the tranny fluid should be done at no more than 75K as for the other stuff... i am not sure.. |
08-20-2018, 10:55 AM | #3 |
Rep 1,709
I'm at 80k miles and I'm doing all these things this fall. From what I've read people either say "if you can afford it do it" or, "Its lifetime dont worry". Just pulling the trigger since I plan on having the car another year or 2.
08-20-2018, 01:31 PM | #4 |
Rep 158
As part of this I'm curious how many years factory batteries are lasting before needing replacement. I suppose there are a lot of variables, hotter climates, how long it sat on the lot etc.
Usually at 5 years I start to worry, for me that means next year, but I have not seen any issues yet, but have only had the car a couple months. -Steve 2015 X1 XDrive MSport //BMS Intake |
08-20-2018, 05:46 PM | #5 |
Rep 1,210
My BMW dealer said "lifetime fluid" is rated at 100,000 miles. My battery went out on my 335i six years after the build date. I would do your diff when you do the transmission. I would do your coolant when you replace the water pump and thermostat. Suspension is completely up to the driver. I would look to do the timing chain between 100,000 and 120,000. As for the belt system I have heard horror stories about the N55 eating the belt through the crank seal. I don't know if that is an issue for the N20 though. Most N55's are replacing them between 60,000 and 80,000 miles.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
08-20-2018, 07:55 PM | #6 | |
Rep 428
If you mean car batteries, before BMW I looked for replacements every 3-4 years (battery in engine bay with my Mazda 6). I've had good dealing with BMW batteries being in the trunk so far, but haven't had the opportunity to pass the 3-4 year mark as of yet with a single battery. AGMs should last longer of course.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
08-21-2018, 12:00 AM | #8 |
Rep 1,210
Because only a company would tell you it is. Anyone with any knowledge knows there is no such thing as lifetime fluid. Glad I could help.
08-21-2018, 07:29 AM | #9 | |
Rep 268
All that being said, good plan to do the fluids 60-75K range. IMHO transmission is the biggest one to do: ZF makes a good transmission, and I trust them a bit more then BMW on the maint interval. Most kits come with the Mechatronic sleeve but to me if that is dry leave it be no need to replace. No affiliation, I used https://www.thectsc.com/ for their kit on the 335d. ZF fluid is more but I am fine with that, if not there are a few other fluids that carry the same spec. While its up in the air, do not forget the transfer case fluid. Its not a lot of fluid, but it is a PITA to get to on the X Drives. Our N55 just crossed 62K and I plan on doing the driveline fluid change within a year. - b |
08-21-2018, 12:24 PM | #10 |
Rep 1,343
Pretty sure there is a thread topic on maintenance here. If not check the F30 section.
As for the tranny fluid, I noticed that my local BMW dealership sells fluid and filter kits for our ZF8 despite the whole "lifetime fluid". Interestingly the service dept. refuses to perform the change unless there's something wrong with the tranny. My car is at about 77k km and I've done all fluid changes except tranny. Will tackle that at 100k km. Or sooner. So far the only tricky one I've experienced is the xfer case fluid. There is a thread about it that I have appended my thoughts and tips. Modern BMWs come with AGM batteries. They are more advanced than the regular lead ones and are able to cope with the electronic stress associated with modern European cars. That said one of the SA I spoke with told me that weak battery can lead to faulty/false alarm sensor codes. It is a good idea to keep a batter tender and charge the AGM battery every so often to keep it healthy. |
08-21-2018, 06:40 PM | #11 | |
Rep 158
-Steve 2015 BMW X! 35i MSport // BMS Intake |
08-23-2018, 12:25 AM | #12 | |
Rep 1,343
BTW that ECU reset can be done through the iCarly app. |
