      06-02-2015, 02:47 AM   #1
jaeezzy
Enthusiast
jaeezzy's Avatar
28
Drives: BMW X1 sDrive18d M Sport
How to remove boot (hatch door) trims?
Any suggestions would be appreciated..
I'm planning to install some sound deadening to all the 5 doors hoping it will cut down some road noise. I noticed that the rear passenger and hatch doors have less sound deadening installed compared to front doors and I don't want to go pulling out trims without a clue I have seen BAVSound video to use as a reference to pull trims out for the front & passenger doors but couldn't find anywhere for the hatch door. Thanks..
jaeezzy...
      06-20-2015, 08:17 AM   #2
scottvh
Drives: 2010 335d
Check out the Bavsound website-their install videos show how to remove the front door trims and the rear hatch area trim. I bet the rear door trims a re pretty similar to the fronts.
Bavsound(dot)com
      07-08-2015, 09:07 AM   #3
jaeezzy
Enthusiast
jaeezzy's Avatar
28
Thanks scottvh that's what I'm referring to for the rear door but hatch is bit different.
I saw 4 screws so far screwing the plastic bit to the hatch. Is that all screws there are or are there more?? After unscrewing I'm thinking rest are just clips that I should be able to just pull out?
jaeezzy...
      07-08-2015, 09:22 AM   #4
improvius
Drives: 2015 X1 X28i
You mean the sill cover? Yep, it's just four screws - two small ones and two larger ones at the tie-down points. Then you can just pull it up. There are metal tabs, so they'll make some loud noise when you pull it up, but nothing will break, so don't worry. You may need to pull back the weatherstripping a bit to get started.
      07-08-2015, 10:08 PM   #5
jaeezzy
Enthusiast
jaeezzy's Avatar
28
No I mean the plastic trim on the hatch door - which holds the hazard sign. I want to get to the metal of the hatch door so that I can install some dynamat and sound insulation. I saw 4 screws on it so far - 2 easily visible and 2 underneath the hazard sign. Just wanted to confirm there are no other hidden screws so that I don't break the trim Thanks
jaeezzy...
      07-12-2015, 07:38 PM   #6
jaeezzy
Enthusiast
jaeezzy's Avatar
28
I tried to take it off on Saturday and unscrewed those 4 screws but taking off the trim was bit tricky. It's definitely hard intact so was bit scared to try too hard and risk breaking sth so just left it
jaeezzy...
      07-12-2015, 07:44 PM   #7
improvius
Does this help?
http://www.realoem.com/bmw/enUS/show...diagId=51_7434
      07-14-2015, 05:21 AM   #8
jaeezzy
Enthusiast
jaeezzy's Avatar
28
looks like it might.. might give it another crack.. cheers!!
jaeezzy...
      07-15-2015, 04:15 PM   #9
rps
rps's Avatar
Drives: 2013 X1
I went by the dealer yesterday to find out how to remove the headlight module so that I could install the euro switch. The service tech gave me a print out of how to do it. If you have a good relationship with your dealer, they could probably give you the print out of the rear hatch panel and trim.
NB8S Past Garage: Z4, 135i. Present Garage: 2013 X Drive X1 2.8i.
      07-15-2015, 07:00 PM   #10
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
It's hold by the four screws and tabs along the edge. I recommend using trim removal tools so you don't break the tabs.
      07-16-2015, 09:22 AM   #11
jaeezzy
Enthusiast
jaeezzy's Avatar
28
have you actually removed it? it's a tight fit so needs a hard pull so bit scared... it would be nice to know which side to start pulling from.. thanks
jaeezzy...
      07-16-2015, 09:26 AM   #12
jaeezzy
Enthusiast
jaeezzy's Avatar
28
I doubt it.. last time I asked them how to remove the mirror cover, they refused to tell as they feared if I were to break it I would came back and blame them.. May be you could ask them and share them here
jaeezzy...
      07-16-2015, 09:50 AM   #13
d1saster
Bulgaria
60
Yes i removed it to get access to the lights. If i have time tonight I'll print out the instructions ao you know where exactly the tabs are.
      07-17-2015, 02:00 AM   #14
jaeezzy
Enthusiast
jaeezzy's Avatar
28
That would be awesome..thanks.. also please let me know which section to start with. Thanks
jaeezzy...
      07-18-2015, 01:34 AM   #15
d1saster
Bulgaria
60
Removing and Installing Trim for Tailgate
I really don't remember where I started from but hopefully the attached instructions will help.
There's something I didn't know and I can't understand well what it means:
US version only
Feed out tailgate lock with emergency release (3).
      07-19-2015, 12:27 AM   #16
jaeezzy
Enthusiast
jaeezzy's Avatar
28
US version only
Awesome.. thanks for the manual.
I'm guessing it means there's a latch that you can pull to unlock hatch from inside - pull it so that the hatch is in unlocked position?
jaeezzy...
      07-19-2015, 03:54 AM   #17
jaeezzy
Enthusiast
jaeezzy's Avatar
28
Finally took it off.. phew!! I was able to somehow convince myself that nothing will break pulled it hard and there it was with all those frightening sound which were hard to tell if that were clips coming off or things breaking.. lol
Thanks guys for all your help.. cheers!!!
jaeezzy...
      07-19-2015, 08:12 AM   #18
jaeezzy
Enthusiast
jaeezzy's Avatar
28
US version only
ok I know what it means - that emergency release is connected to the hatch so one has to be careful to take it off before completely removing the trim otherwise it can damage the trim or you snap the emergency release wire altogether.
AU models as well have this emergency hatch release in the hatch itself. I have seen some models where the release is underneath the dash in the front like the hood release. We don't have this.
jaeezzy...
