      07-14-2014, 12:47 PM   #1
Biggest BMW Fan
Biggest BMW Fan's Avatar
South Africa
Drives: BMW X1 sDrive 20d
Smile Xenon Headlights
Okay, so I've got a 2013 / 2014 model X1 20d with halogen headlights. Is it possible to have BMW OEM xenon lights retrofitted?
I'm worried about fitting non OEM xenon / HID lights which may void my 5 year / 100,000KM motor plan.
Could someone please give me some suggestions.
      07-14-2014, 10:04 PM   #2
halfmoonclip
Drives: X1 28i
Having lost one to a stray deer, I'll tell you that the HIDs are brutally expensive.
How many watts are your standard bulbs? I put a set of E-codes in a TJ Jeep, and installed 100w bulbs and relays....it actually gives you remarkably good lights, but the relays are necessary. 'Till the power runs from the battery to the steering column and back, there is a voltage loss. The standard setup doesn't use relays in the Beemer? If it does, just upgrade your bulbs and see what you think.
Moon
      07-14-2014, 11:46 PM   #3
Biggest BMW Fan
South Africa
Moon
I'll have to come back to you on the watts of the standard bulbs Moon.
      07-15-2014, 08:26 AM   #4
ca318i
Drives: BMW X1 Sdrive 20d
Hi, The standard halogen headlights are all 55 Watt, low beam and high beam.
      07-15-2014, 08:39 PM   #5
Twix
Twix's Avatar
Drives: 2011 e91
Yes you can retro fit. Yes it will be expensive. There's a long thread on here about a guy that went through the process. Synopsis was, don't bother unless you feel that you REALLY need them.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      07-15-2014, 10:07 PM   #6
halfmoonclip
Drives: X1 28i
Twix, that makes a ton of sense and pretty much sez it all.
Are the standard lights run thru' relays? If so, uprating the bulbs should make a huge difference.
Moon
      07-15-2014, 11:55 PM   #7
Biggest BMW Fan
South Africa
Moon
Maybe I must just put the idea to bed and forget about it ...
