      07-04-2014, 01:35 AM   #1
SEEMENOMORE
Drives: 2015 BMW X1 xDrive28i
Bluetooth option for streaming music
iClever Himbox HB01 Bluetooth 4.0 Hands-Free Car Kit for Cars for $29.99+ FS @ Amazon
http://www.amazon.com/gp/product/B00GJFGE0K
Use coupon L84G8KK8
- The latest Bluetooth 4.0 (fully backward compatible) for full-speed transmission and low power consumption
- Provide a simple hands-free solution for answering and receiving phone calls and streaming music from your Bluetooth-enabled phones while on the go
- Free Dual USB car charger included, capable of charging two devices simultaneously
- Echo and noise canceling technology supply a more clear call quality
- Built-in microphone and built-in high performance stereo audio codec
I did some research and discovered that a majority of people that wish to stream music usually go with the blackberry music gateway but this is a more cost effective alternative. I can not attest to the quality of the blackberry music gateway since I have yet to use one but this device works like a charm. Plug and play without ever having to turn the device on. The wires are somewhat thin but if you just stow it away in the cubby by the USB port you should have no problem. Found a coupon code to drop the price to $29 when checking out but not sure how long it will last. Hopefully someone finds this helpful.
      07-12-2014, 03:15 PM   #2
aferguson7
Drives: 2014 BMW X135i Xdrive MSport
I use the kinovo bluetooth adapter and have it hidden in the little hole below the stereo out of the way so you can't really see it.
      07-13-2014, 07:47 AM   #3
tominavl
Keeping it Real
Drives: 2014 X Drive 2.8i Sport Line
I checked this out and it's designed to add bluetooth to a computer. Yet a hidden feature is it will enable streaming music on my lame BT system? Awesome!!! Since you have to plug it into the USB port, then your phone cannot be charged while in the car, right? I suppose I could find a splitter for the single port to solve that problem, though I hate junking up the console.
