      10-27-2014, 09:50 AM   #1
Redsoxx1918
Drives:
Service interval
My first three BMWs had a 15000 service interval for oil and filter change. My 2013 X1 was set for 13000 miles. My 2015 X1 is set for 10000 miles. When I hit 700 miles, it dropped to 9000 miles. I guess BMW is figuring out that these new turbo engines need more frequent oil changes.
      10-27-2014, 11:31 AM   #2
NumberSix
Veloce
NumberSix's Avatar
Drives: Future X1???
Remember, the computer that determines when the oil is changed is not just based on mileage, but also on the style of driving you do. Then, again I think you're on the right track with the turbo on any car requires more frequent oil changes.
I may not have ended up where I intended to go,
but I know I've ended up where I'm intended to be.
-Douglas Adams
      10-27-2014, 12:02 PM   #3
Red Bread
Drives: Smog machines
Agreed, the intervals are set on amount of fuel consumed. But they did lower intervals last year, seven years after they started seriously expanding turbo offerings.
      10-27-2014, 02:16 PM   #4
Twix
Twix's Avatar
Drives: 2011 e91
I still would never rely on BMW intervals. Get your oil changed sooner, you'll thank me in 100k miles.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      10-27-2014, 02:39 PM   #5
elfhearse
CW5
elfhearse's Avatar
Drives: 14 x28iS/10 e91M/00 Z3MC
2014 BMW x28i  [0.00]
2010 328iT  [0.00]
Condition Based Service.. mine is averaging every 10K miles for oil change (I do my own oil change in between to make it a 5K mile oil service for the turbo)
CURRENT:
10 328iT ZMP-6spd, 00 Z3 MCoupe, 76 2002 stg.2 5 speed
PAST: 96 318ti Cali, 03 325Ci, 00 Z3 M Roadster, 99 Z3 2.8 Coupe, 14 X128i M-Sport14 Z4 28i Sport 6-spd
      10-27-2014, 05:17 PM   #6
Lucky13
Lucky13
They changed the service interval for 2015 X1's. It is 10,000 miles on the 2 series so it will be plus or minus 1,000 miles from the 10,000 based on how you drive. Yes they figured it out.
      10-27-2014, 07:31 PM   #7
GTony
Australia
27
Drives: 2015 X3 F25 XDrive 28i M Sport
I just finished long comments.
Logged on before, so no idea what happened.
Will redo later.
      10-28-2014, 09:31 AM   #8
Kevman
Kevman's Avatar
44
Drives: 2019 BMW X3 x30i
Got my first 3 oil changes at dealer at 15-16k intervals, as per car settings. Going 10k from now on.
      10-30-2014, 10:06 PM   #9
atomic
Drives: 2016 x3 x-line white
My first oil change was at 4500 miles. It currently states my second one will be at 8000 miles. If you are getting 15k miles between oil changes perhaps you are driving like an old lady. Try driving in sport mode once in a while.
      10-31-2014, 12:48 AM   #10
Teutonic
Teutonic's Avatar
Replacing my oil every 5000 km. one oil change free from BMW, one I pay for it and so on. My first oil change was when the vehicle had 1000km and I did that for each car I ever owned. There are litle particules that need to be pulled out.
My engine loves me.
      10-31-2014, 12:45 PM   #11
atomic
My engine loves me.
But the environment hates you for needlessly changing your oil more than necessary for long engine life.
      10-31-2014, 04:13 PM   #12
Kevman
Kevman's Avatar
44
I do not drive like no grandma...push my X1 pretty hard. But the oil change indicator on 2013s is set to 16,000 miles. Drops to 10,000 miles 2014. Dealer would not budge on this. Will not use him going forward.
      10-31-2014, 05:18 PM   #13
Twix
Twix's Avatar
Drives: 2011 e91
My 2014 was one month shy of being built to the new intervals, my dealer wouldn't budge on the intervals for my car either. 24000 KM is way too long between oil changes no matter what oil you use and how you drive. I just pay for one every 5000 anyways. It's not like it breaks the bank.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      10-31-2014, 06:24 PM   #14
Lucky13
Lucky13
It's not a retroactive deal, if you have BMW's from an earlier time you are screwed.
      11-02-2014, 09:05 AM   #15
Teutonic
Teutonic's Avatar
Actually, it should love me. The old oil is sent by the dealership back in proper conditions. Plus I tend to keep my cars for 5-7 years, sometimes more, I actualy think I help the environment. Fresh oil means lower emissions too.
      11-02-2014, 10:48 AM   #16
Redsoxx1918
Drives:
My engine loves me.
You should be driving a Nissan Leaf
      11-02-2014, 03:36 PM   #17
atomic
If had my last vehicle for around the same amount of time and change the recommended mileage and I am sure someone else is driving it now.
      11-06-2014, 05:21 PM   #18
GTony
Australia
27
D.I.Y. Circumstances.
You will see that mine is a diesel. My BMW recommended from new was every 2 years or 24 to 30,000 Km's because of the high standard of oil they use. I understand they have now lowered this. I rang Castrol Tech. Dept. long time back and even though they agreed oil was good for 2 years they said it would be better to change yearly. Sales pitch or not I've always had mine changed at yearly service, around 12,000 Km's.
Oil used on BMW Invoice showed 5.2 LTRS and charged around AUD$200. Out of Service Oil Change is AUD$350.
My Warranty runs out end of this year and I will be doing my own changes.
Q.) Next I will be doing less Km's and I believe if your car isn't driven much, You should change your oil even more frequently.
Of all the oil change forums I've seen when they say drain oil, presumably on level surface or ramps etc.
Stupid or not my Questions are.
1) Via Dipstick, how is the best way to check oil, presume level surface.
A. Engine cold.
B. Engine warm or hot.
2) What is the 1'st thing done.
A. Do you just change the oil when cold, OR
B. Do you warm the engine up 1'st. I realize that if you use ramps that oil will be mixed through and warm. Do you warm it up a bit more or wait for it to cool on ramp before changing.
The above Questions might be funny to some but I want to make sure I drain the Maximum amount of oil.
Don't be to hard on me Guy's.
      11-06-2014, 05:55 PM   #19
d1saster
Bulgaria
59
Drives: F15 N55 & E93 N51
Those are valuable concerns you have. What's the year and engine you have? I'll check on ISTA D the exact instructions.
      11-06-2014, 11:42 PM   #20
mcduck
Drives: 2013 X1 Sport Line
I took my 2013 X1 with 6,715 km on it in to have the winter tires installed and requested an oil change. The SA said that was no problem and that the computer was showing I was due for a brake fliud service and new micro filter in Febuary, so he would do those services now to save me a trip back to the dealership.
I ended up with an X1 because of the great service my wife was getting on her 2012 128, and I have not been disappointed with the car or the dealership (who is the only BMW dealer for a few thousand kilometres).
The new building that they just moved into is designed so that the customer lounge looks directly into the service bays so that you can get a coffee and watch your car being serviced.
      11-07-2014, 02:15 AM   #21
0w40X1
Drives: 2014 BMW X1 s28i M Sport
GTony,
Drive your car on to ramps after engine is warmed up, but wait 30-60 minutes so you don't burn your hand.
While oil drains change oil filter if you can reach.
Pour in recommended amount, and check that about that much came out.
Move car off ramp, and recheck dipstick hot or cold.
Next time it's cold before starting recheck dipstick to confirm oil level.
      11-07-2014, 10:15 AM   #22
Shredjim
Drives: 2014 x28 X1
Sounds like diesels come with a dipstick? Maybe the other countrys get them, but here in the US the 28i's don't have dipsticks. The oil level gauge is electronic. I miss having a temperature gauge more.
