      04-10-2015, 11:18 AM   #1
mwtrogus
Drives: 2014 X1 35i
X1 35i SprintBooster review...
I wanted to do a quick writeup on the SprintBooster (SBBM1002s)product that I have installed a couple of months ago. I went back and forth on this purchase for quite a while as they are very expensive (approx $289 for) a simple plug and play throttle signal booster. Good reviews are out there, but many people don't try it due to the high price tag... I love it!
https://www.sprintboosterusa.com/
Install is very easy and you just have to take the bolt out of the bottom of the pedal and then slide it out towards the brake pedal. The new Sprint Booster harness snaps into place and I have it zip tied into a bundle at the top of the pedal, then the remote switch can be mounted wherever you want. I simply ran the wire in the center console and the switch is near my right knee where the carpet meets the plastic center console.
I have tried the 3 maps for throttle and just cant say enough great things about the product. 95% of driving is in the middle map, Stage 1(Green light). It really increases the response of the pedal input and no lag exists, true throttle position is registered in the ecu. I even see the immediate response of the throttle opening while doing "logs" with the JB4 tune. In the past the pedal position would be at 100%, but the throttle would take a very long time to open to 100%, now it shows dramatic difference on my logs.
The car should perform like this from the factory and not have the ridiculous pedal delay. I thinks this product works very well with the Alpina flash for the 6 speed auto as it makes power and torque easier at the low rpms in regular drive mode as the Alpine shifts very early in D.
I have turned it off on numerous occasions just to reinforce my thoughts about how much I love this product.
I'd buy it, they do have a 30 day return option if not satisfied! Try it out and see for yourself. It should be a $49 product and everyone would buy it!
I have several mods and changes on my car and this is near the top of the list to change the driving feel of the car and make it a great daily driver. If anyone else has feedback feel free to chime in...
      04-10-2015, 03:55 PM   #2
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Thanks for your report. I am very uncomfortable with the throttle response on my X1, and this sounds like a solution. Are there any negative side effects?
      04-10-2015, 09:19 PM   #3
Nova Rounder
Drives: 2015 X1 xdrive 28i M Sport
drop on MPG, not sure how much on X1 but with my Lexus it dropped around 3mpg, but yes no more delay on throttle response and there is your give and take.
      04-10-2015, 09:44 PM   #4
mwtrogus
Drives: 2014 X1 35i
You can click the button at any time and you will be back to stock setup. It sucks that it costs close to $300 bucks, that's the negative!
      04-11-2015, 11:05 AM   #5
PGZ11
Drives: 335XI
so you are running this on top of jb4?
      04-12-2015, 07:38 PM   #6
mwtrogus
Drives: 2014 X1 35i
Yes JB4 ISO w/ ff wires to run e85 mix.
      04-15-2015, 09:27 PM   #7
Nova Rounder
if I use sprint booster, will that void my warranty if something goes wrong and they find out I'm running with it?
      04-16-2015, 09:07 AM   #8
mwtrogus
Drives: 2014 X1 35i
not sure on the warranty, it takes 10 minutes to install and less time to uninstall if you have an issue or concern.
It has option to be installed and essentially be in the "off" position and then has 2 other settings or levels of sensitivity control. It really improves the driving experience... but again it is expensive for what it is
      04-16-2015, 01:35 PM   #9
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
The information on their website is very vague. What's the stage 1, 2, etc thingie? Is it a remote on a wire? It isn't a tuning device, is it?
      04-16-2015, 09:29 PM   #10
mwtrogus
Drives: 2014 X1 35i
Check out the link in the first post and then hit the "media" tab, the first video does a good job at explaining how it works and the stages. I think the green light is ideal for daily driving. The remote is on a wire and can be mounted or you can just set it to stage 1 and remove the remote as it will just stay on stage 1 setting. All it does is open the throttle more quickly, I guess this could lead to better/faster performance, but for me it was about the huge improvement in drivability by removIng that annoying throttle lag.
      05-07-2015, 02:52 PM   #11
Nova Rounder
just got my Sprint Booster for my x28... I will update this thread on how it is while running with it soon.
      05-08-2015, 09:38 AM   #12
MMacx1
MMacx1's Avatar
Drives: 2016 BMW 340i M
$300.00
I really need this, but $300. Could we start up a Group Buy.
      05-08-2015, 09:57 AM   #13
themishmosh
Drives: BMW X1 xDrive35i
Nice. Never knew this product even existed! Thanks for the review!
      05-09-2015, 09:44 AM   #14
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
Drives: Audi BMW Ferrari LR MB
out of curiosity why did you go with sprint booster over a tune? the tune would give you additional power and mitigate DBW lag and improve drive-ability overall.
      05-09-2015, 09:54 PM   #15
mwtrogus
Drives: 2014 X1 35i
I do use JB4 stage 2 with ISO. The piggyback JB4 or Cobb tune doesn't help with electronic throttle lag. I have no idea if Dinan flash does anything with the throttle. I also have the Alpina trans flash so that changes the 6sp auto shift points dramatically.
      05-12-2015, 09:40 PM   #16
themishmosh
Just received my Sprint Booster and installed it. With just a go around the neighborhood, I definitely like the quicker response. The Aggressive mode is a little much but the medium setting is perfect. Thanks again for your review. I previously never noticed a throttle delay but clearly after using the Sprint Booster, there is some.
      05-15-2015, 11:18 PM   #17
MMacx1
MMacx1's Avatar
Booster
I have the Dinan Stage 1 Tune , but still have the 1 sec. delay
28i
      10-20-2017, 12:04 PM   #18
SharpAndCunning
Drives: 2014 X1 35i
Doesn't sprintbooster just modify the throttle input, so say 10% of throttle input is now 25/30% of WOT. It takes any linear response out of it, and "re-maps" it.
How is that actually eliminating throttle delay? Cant you just push down on the pedal faster?
      10-20-2017, 12:58 PM   #19
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
I'm not sure how this sprint booster works but JB4 now has menu 11 which will remap the throttle and MHD is out for late N55's now. Both of those will eliminate the throttle lag and provide more power.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      10-20-2017, 04:37 PM   #20
Ja Gio
Drives: X1 xDrive28i, 2013
It does simply remap the throttle, but it takes it from “less than linear to more than linear” - so to speak. It goes from from something like 50% = 1/3, to 50% = 2/3. I don’t think it effects throttle delay.
I use it and like it - the car feels a bit lazy without it.
      10-20-2017, 06:50 PM   #21
themishmosh
I uninstalled mine. Definitely make driving smoothly harder. I don't think there is any lag in our cars when you have it in manual mode...at least for the 35i. I even don't like aggressive mapping in JB4 throttle adjustment.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      10-22-2017, 09:40 PM   #22
Turbod
Turbod's Avatar
I found the JB4 adjustments to be pretty extreme and had mine set pretty low. I also found that you would overboost at part throttle.
2023 G80 M3 xDrive
