      12-19-2014, 12:39 PM   #1
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
DINANTRONICS for the X1 28i Available Now.
I know there has been a pretty steady demand for the X3 and X4 cars that are now supported but this newest release is also compatible with the X1 cars as well so you can take advantage of getting some extra power while not sacrificing your factory warranty-- a Dinan hallmark. With a rough maximum gain of 40 HP and 40 ft-lb of torque now your 28i is essentially turned into a 35i!
Performance graph is below. Feel free to ask any questions if you have any.
Please note that the X1 35i is already supported via a software flash hence why they are not included in this release.
      12-19-2014, 01:14 PM   #2
Aerospike
Drives: 2013 F20 M135i
Could you please elaborate? I thought any mod/reflash to any of the drivetrain components voided the warranty? Is it the same for the 35?
Thank you,
Mo
      12-19-2014, 01:38 PM   #3
Dinan_Engineering
Drives: Any BMW
Thank you,
Mo
Dinan offers a factory matching 4yr/50k new car warranty. Essentially what this means is there are 2 concurrently running warranties. The short of it is either BMW or Dinan will cover any warranty issues. How we have handled situations over the past 25+ years with BMW NA is if BMW NA feels that something related to a Dinan product is to blame for a problem we will cover the expense. Simple as that.
You can call us or go to any of our dealers and they can explain any specifics you are curious about.
      12-19-2014, 01:49 PM   #4
Aerospike
Sounds good. Thank you.
      12-19-2014, 04:58 PM   #5
matjen
Drives: 2015 X1 xDrive 28i
Do you have a preferred installer in Chicago area?
      12-19-2014, 05:11 PM   #6
Dinan_Engineering
Drives: Any BMW
A preferred one, no. We do have 4 in the area though. For an experienced independent that has a lot of racing experience to tap into I would recommend Fall Line Motorsports in Buffalo Grove. If you wanted a dealership experience you can't go wrong with either Laurel BMW in Westmont or Patrick BMW in Schaumburg. We also just extremely recently opened up a new independent in Orland Park by the name of Bavarian Auto Werke. Haven't had a lot of exposure to them so I really can't comment on them but they may turn out to be one of our best dealers for all we know. You really can't go wrong with any of them.
      12-19-2014, 05:31 PM   #7
Twix
Twix's Avatar
Drives: 2011 e91
What's the difference between this tune's parameters and the tune for the rest of the N20 powered cars? Why do we get less power?
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      12-19-2014, 05:38 PM   #8
Dinan_Engineering
Drives: Any BMW
There is no difference between this and the other N20 powered cars with an electronic wastegate. The mechanical wastegate vehicles showed slightly more power (312/330) but for all practical purposes they are the same. The difference is the equivalent to a rounding error although the power edlivery between the two wastegate versions differs a bit. The mechanical wastegate vehicles tend to have a bit more 'harsh' power delivery where the electronic wastegate is a bit smoother due to finer control of the wastegate itself.
      12-19-2014, 05:40 PM   #9
Twix
Twix's Avatar
Drives: 2011 e91
I'll order tomorrow from my dealer, they're a Dinan authorized group. Any discounts? lol
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      12-19-2014, 05:48 PM   #10
Dinan_Engineering
Drives: Any BMW
Nothing at the factory level unfortunately but each dealer has free reign over what they ultimately want to sell things for so it can't hurt to ask and see if they are willing to do something on pricing.
      12-19-2014, 05:50 PM   #11
Twix
Twix's Avatar
Drives: 2011 e91
One last question. If I were to install a carless down pipe, would the Dinantronics keep the idiot light off? I'd really like to delete my cat
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      12-19-2014, 06:38 PM   #12
Dinan_Engineering
Drives: Any BMW
The CEL would still be present. The DINANTRONICS Tuner integrates fully with the factory setup and does not clear codes. The whole point of our system was to create a factory-like system that didn't need to clear codes by interfacing with every necessary subsystem so that the built-in factory safeguards were retained. Whereas some tuner systems simply interface with a couple select sensors the DINANTRONICS Performance tuner ties directly into the factory ECU and is able to interface with any signal coming and going. This equates into sublime drivability which typically sets Dinan apart.
      12-19-2014, 06:55 PM   #13
matjen
Is it fair to assume that there is no difference from a warranty perspective if a Dealer or authorized independent installs it? My X1 is only a few months old so don't want to lessen any warranty support.
      12-19-2014, 06:59 PM   #14
Dinan_Engineering
Drives: Any BMW
Nope. No difference from a warranty perspective.
      12-19-2014, 07:47 PM   #15
paradoxical3
Can you specifically explain how the dinantronics piggyback unit ties directly into the factory ECU to a degree that the Burger Motorsports JB4 does not? It is hard to understand how that is the case when you are utilizing the same connectors they are.
It is my understanding that the encryption for the N20 and N55 engines has yet to be cracked, which means that Dinan cannot access the actual ECU parameters/maps anymore than any other tuner could.
This quote from your website is patently false, to to the best of my knowledge:
The DINANTRONICS™ Performance Tuner uniquely has the capability to adjust target Lambda, correct short term trim as well as ignition timing errors induced by raising boost pressure. This enables Dinan calibration engineers to optimize air/fuel mixture and ignition timing at elevated boost pressure throughout the entire gamut of engine RPM and engine load.
With the N55 and N20 engines how can you adjust target Lambda when no flash tuning exists outside of a select few 2011 models with the proper DME? Further, are you saying that you can correct timing errors simply by raising boost? If that is the case, any piggyback would be able to do so (surely you are not claiming that only Dinan piggybacks can raise boost).
Are you really claiming to be able to manipulate AFR ratios at specific RPMs when no other tuner can? Do you have hard data to back this up?
      12-19-2014, 09:16 PM   #16
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
Then you are misinformed as myself and a few others here have the Dinan tune flashed in our ECMs for the N55.
Please don't turn this thread into a crapfest because you happen to use the Burger Motorsports JB harness paradoxical3.
Dinan, thanks for continuing to work on the N20 based X models, especially the X1.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      12-19-2014, 09:18 PM   #17
paradoxical3
Dinantronics for the N20 is specifically a piggyback. Just like the Jb4
http://dinancars.com/product/d440-16...-f10-528i-n20/
      12-19-2014, 09:21 PM   #18
CIWS
Moon Parasite
CIWS's Avatar
Ok, but what does that have to do with you saying the encryption wasn't broken by Dinan on the N55 ?
      12-20-2014, 08:19 PM   #19
atomic
Drives: 2016 x3 x-line white
What do you care you don't have an N20 engine?
      12-20-2014, 09:46 PM   #20
x1-2012
x1-2012's Avatar
Drives: BMW X1 x28i
Hi, Dinan's web site indicates the D440-1619-ST1 is for the X1 28i 2013-2015 .... However can it fit on my Canadian X1 28i manufactured in February 2012 ?
      12-20-2014, 09:58 PM   #21
paradoxical3
Because I dislike false advertising. The question is, why don't you care if you do have a N20 engine? Dinan claims they can adjust target lambda via piggyback when no other tuner can.
I am simply asking how that is the case.
      12-21-2014, 06:10 PM   #22
Dandaman184
Drives: 2013 X1 (Sold)
What if we have an extended full warranty of 6yr/100k miles, does it impact that at all? Thanks
