      05-03-2016, 05:24 AM   #1
Rozay
Drives: 2015 x1 s28i
Wheels and drop
Hi there just got a 15 x1 s28i coming from a Mustang 5.0.
My h&r springs will be here tomorrow and I'll install this week hopefully if I got time to do so. My question is i want to get some 20x8.5 et35 all around bbs reps I found online. Will i have any problems with rubbing? Here's what my 5.0 looked like
https://www.dropbox.com/s/2qopzdx9h7..._3116.jpg?dl=0
      05-03-2016, 05:26 AM   #2
Rozay
Here's the new ride
https://www.dropbox.com/s/1ghfhngvja...24813.jpg?dl=0
      05-03-2016, 08:30 AM   #3
themishmosh
Drives: BMW X1 xDrive35i
Welcome. What's the story with the Mustang-to-X1? Or is the X1 your daily driver in addition to the Mustang?
      05-03-2016, 09:51 AM   #4
PrematureApex
Plenty of room for an 8.5" wheel with a 35 offset. You may want spacers even.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      05-03-2016, 09:52 AM   #5
Rozay
Trying to buy a house so needed to get rid of Mustang.
      05-03-2016, 09:53 AM   #6
Rozay
Thanks for the answer.
      05-03-2016, 11:30 AM   #7
Rozay
So with that offset how many mm would I need front and rear to be flushed with spacers
      05-03-2016, 12:02 PM   #8
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Stock offset is 30mm, and what size tires are you going to use?
Use this link...http://www.rimsntires.com/specspro.jsp
      05-03-2016, 04:01 PM   #9
Rozay
Thinking of using 245/35/20 or higher sidewall like 40 if it can fit
      05-03-2016, 04:09 PM   #10
PrematureApex
Car is slow enough as it is without killing the gearing like that. I'd stick to stockish overall height. If you're worried about the ride, how about 19s?
You may want in the neighborhood of 15mm spacers.
      05-03-2016, 06:46 PM   #11
Rozay
ive been reading a bunch today and ill stick to 18" wheels 8.0F 8.5R wrapping it with 225/40/18 all around with the H&R springs
      05-04-2016, 02:55 AM   #12
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
If you are using 225 tires all around just keep same width wheel. Since its rwd though why not at least do the factory staggered setup?
      05-11-2016, 05:27 AM   #13
Rozay
Ok so I've been dropped on h&r for 5 days now and bought some 19x8.5 19x9.5 et35 all around. Will 245/40/19 work all around? I like the slight meaty look.
      05-11-2016, 02:39 PM   #14
mwtrogus
Drives: 2014 X1 35i
You'll have clearance issues on the front wheels while turning.
      05-11-2016, 04:07 PM   #15
Rozay
So will I need a smaller tire? Will the new wheels make any contact with the suspension?
      05-11-2016, 05:09 PM   #16
mwtrogus
Drives: 2014 X1 35i
225 is standard up front.
Your wheel will be fine with the 8.5 and et35. If not, you always have spacers to adjust the strut clearance. You'll just get rubbing on the inner fender when turning, it's not that big of a deal.
I'd just use the spec'd stagger from bmw on the tires. You'll probably end up buying 15mm spacers anyway to push all the wheels further out
      05-11-2016, 05:25 PM   #17
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
I'm running 245 9x20 et35 in the front and 275 10x20 et 40 in the rear and I'm not rubbing anywhere.
      05-11-2016, 06:50 PM   #18
Rozay
Cool guys thanks once I get the wheels and tires in I'll post some pics.
      05-11-2016, 06:51 PM   #19
Rozay
Did you have to get spacers for the front to be flush with fenders? I'd like to be flush
      05-11-2016, 07:04 PM   #20
mwtrogus
Drives: 2014 X1 35i
Is your car lowered from stock height?
      05-11-2016, 07:16 PM   #21
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
Yes I got H&R springs on.
Check out my thread to see how it looks.
http://e84.xbimmers.com/forums/showthread.php?t=1260738
      05-11-2016, 07:17 PM   #22
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
No spaces needed, it's flush all the way around.
