      06-17-2013, 10:02 PM   #1
Chrakaknox
Drives: X1 35i M-sport
Centering rings for O.Z. wheels
I have been researching a lot of wheels lately and found O.Z. Ultraleggera's that struck my fancy. However, I've never had wheels that needed centering rings. How good/bad is it that they need them and can it cause any future issues? Otherwise, the wheels are really light and they come in black, which is what I am looking for.... Anyone have any experience with these wheels and/or anything else that needed centering rings??
'14 Valencia Orange/Black X1 35i M-sport
BMS N55 intake
18x8 29et Black lightweight wheels w/ 235/45/18's
      06-17-2013, 11:46 PM   #2
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
i was looking at same ones but also look at these lighter and cheaper enkie raijin-19 and enkei rsm9
      06-18-2013, 08:25 AM   #3
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
Of course correct center bores are ideal, but I've purchased several sets of wheels with centering rings over the years. As long as you're buying from a reputable source (such as the Tire Rack), centering rings shouldn't be need for concern. The rings can stick to the hub, so a little anti-seize can help prevent problems.
      06-18-2013, 09:24 AM   #4
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
yep...and plastic centering rings can crack. Two of mine broke when pulling off my winter set after only being on the car for 4 months. Anti-seize may have made a difference...not sure.
      06-18-2013, 09:48 AM   #5
benaj
Drives: 2014 X1
No need to worry at all about using wheels that need centering rings. The lug nuts are the important issue to have match (ball vs cone mount), the wheels won't fall off because you mounted them with centering rings.
The best are the centering rings that are made out of aluminum and have a snap ring to keep them attached to the wheel. The least desirable are the plastic centering rings that can occasionally crack during a wheel change or melt (when using them on the track or autox). That being said, we have used wheels with plastic centering rings for years on our cars without any issues. And if there is an issue, generic replacements can be found anywhere if lost, broken, melted, etc.
Good luck.
2021 X5 x40i M sport
2014 X1 x2.8 M sport
2011 128i sport 6mt
1998 M3 sedan - her track toy
1995 M3 coupe - his club racing toy
      06-18-2013, 03:40 PM   #6
Chrakaknox
Great, thanks so much for your feedback. I like those Enkei wheels mentioned earlier too, just can't decide yet....
BMS N55 intake
      06-19-2013, 12:16 AM   #7
benaj
Drives: 2014 X1
Once you do decide, please post pictures and specs of your new shoes on the aftermarket wheel thread for others to see.
      06-19-2013, 07:26 AM   #8
HotRodW
HotRodW's Avatar
If you like the style of the Enkei Raijin, you may want to take a look at VMR's, too.
http://www.velocitymotoring.com/
I put matte black VMR 710's on my wife's Q5, and she absolutely loves them. I am impressed with the available styles, price, quality of the finish and aggressive offsets. The color was her choice, and while I would have gone with silver myself, I have to admit she gets a lot of compliments. VMR's are machined with the correct center bore.
      06-19-2013, 08:34 AM   #9
Chrakaknox
I will check them out, thanks for the info....
BMS N55 intake
