      10-01-2018, 10:40 PM   #1
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Tracking my X1 first time , any advice
Stock 2.0t m sport package , stock pzero runflates. Adding 4 psi to tires otherwise stock
      10-02-2018, 09:58 AM   #2
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
Track day or autocross or other?
      10-02-2018, 11:10 AM   #3
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I had P7 summer runflats on my X1 s28i M sport.
When it's hot the fronts would get over 42 psi which is no good.
40 hot is about max for front , and approx 43 hot for rears.
I didn't need to add 4 psi to the 35f 38r cold because the heat gets it too high already.
Of course the Pzero might act different.
If front doesn't grip you have too much in front tires.
      10-02-2018, 12:40 PM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
I did my first track day on the stock Goodyear Eagle All-Season run flats, so you shouldn't have any problems.
Unless you are starting with a morning session I would actually drop your air pressure by 2-4lbs. Your air pressure will increase as you get heat into the tires and this is where you want them running at their optimum pressure.
Big thing is to just have fun!
This post sent using 100% recycled electrons.
