      11-07-2020, 06:55 PM   #1
joshr6
Drives: 2010 bmw x1 20d xdrive E84
X1 E84 20d xdrive, R17 on front & R19 on rear?
Hi, I'm planning on changing to non run flat and want to put R17 on front and R19 on rear. They do fall within bmw tyre recommended size. Just wondering is it ok to have 2 inches difference(R17 and R19) in front and rear tyre size? Thanks
      11-07-2020, 09:21 PM   #2
BeEmVe
Drives: '14 X1 x28i M-Sport
With AWD vehicles one wants the overall tyre diameter size to be the same front to back. Otherwise they rotate at different speeds which greatly affects the differential.
If you go with r17 and r19 wheels the front tires will need to have 1" more sidewall than the rear. Which is going to look stupid to say the least.
You can go wider between front and back but not otherwise.
      11-10-2020, 03:12 AM   #3
joshr6
Thanks mate BeEmVe. Appreciate your insight �� will stick to R18s
      11-10-2020, 03:33 AM   #4
Spectralus
Drives: E84 xDrive 23D
With correct overall tyre diameter it can be done. But I have to agree 17/19 would look just too weird. Probably 18/19 or 19/20 would look ok.
Tags
bmw x1, e84, non run flat, r17, r18, r19, tyre, tyres, wheel, wheels
