      01-19-2024, 08:19 AM   #1
A.T.
Drives: BMW X1, E36 M3
2015 E84 X1 Limp mode?
Hello Bimmer fans.
My wife's 2015 X1 is having a mysterious problem. My usually very capable mechanic seems stumped.
It's having trouble starting. It will crank but seems to be struggling for a few seconds before starting. Then it will just idle but won't rev. and will drive but only as quickly as the low revs allow. I left it to idle and warm up for several minutes. It eventually will drive seemingly normally again. But if you shut it off it will immediately have the same issue. It wasn't showing any dash warning lights, no engine light etc.
We brought (limped) it to our mechanic just a couple blocks from us. It's exhibiting all the same symptoms for him. He did a few scans and it brings up a number of random codes but different ones every time he does the scan. He's checked the battery. That appears to be good. He managed to get it running, took it for a test drive. It all looked good. He parked it. and tried to restart it and the problem was back.
If anyone has any insights it would be greatly appreciated.
Cheers
A.T.
      02-11-2024, 11:47 AM   #2
05X3lover
Drives: '15 Dark Gray X1 AWD
It's probably against forum rules for me to say this, but I would check out a couple of the other BMW forums and post your issue there. This is a great forum but the problem you're mentioning sounds like something beyond what the typical poster here will be able to answer, and on some of the other forums there are BMW master mechanics that post regularly. Someone like that will I bet, know what the issue is. To me it sounds like something to do with the ECU but my knowledge is pretty limited. Good luck and please update if you find a solution.
      02-11-2024, 04:06 PM   #3
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
I see many threads where long cranks end up being caused by a bad low pressure fuel pressure regulator. Here's one such example:
https://www.e90post.com/forums/showthread.php?t=2001844
