06-02-2021, 07:11 AM | #1 |
Rep 157
35i M sport wheel options?
Hey all. Looking at my options for square wheel set up for my 35i m sport DD. I do some small highway road trips and daily ins and outs.
Currently running 225/255 19 Perelli summer. I have a winter set up for WI driving. Also thinking going max diameter to fill the wheel wells a bit more. Not interested in 20s or lowering. Thinking: 225/50/18 square 225/55/17 square Michelin defenders I have followed the tiltmod thread to see some options. But those are all xline not msport suspension set ups. Not sure if the sport suspension is lowered. Any insight?
Pay attention to the person behind the one in front of you.
06-02-2021, 10:31 AM | #2 |
Rep 112
That I'm aware, msport is apperance only.
You can check realoem, look at springs and see if there are two versions. I have 245/45r18s up front. That's about as much as you can fit in that diameter. These are firehawk indy 500s. Just kisses the fenderliner at full lock in parking lot. Rears are 275/40r18, loads of room if you do 18s. Feel like 17s may hit sway bar if too wide. 18x9.5 +35, 5mm front spacers. If i were doing it again if get 9"s, 9.5 is too tight, sticks out. If i did it again I'd go down to e90 sizes. I feel you could fit 275/35r18s up front with work on 9s, and camber |
Duchess2244.00 |
