      01-26-2020, 06:46 PM   #1
jjrolls
Drives: BMW X1
10.25" Android Screen Navigation| Anyone try this? |
Hi guys! Purchased one of those 10.25 inch screens. Has anyone successfully installed this on a '13+ X1?
I can't find a good installation guide.
^ this one really doesn't show much, plus the car has different center console pieces.
Any help would be greatly appreciated! Thank you!
      01-26-2020, 07:46 PM   #2
gbracerx1
Drives: 2013 X1 - Midnight Blue
I have the latest snapdragon black rimmed avin system installed with wireless carplay. Just replaced my 4.4.4 unit.
What do you need to know.
First remove the vents, pry with plastic trim tool at the vents and work to the right. Its just clipped in. Careful of the hazard plug, remove by pulling gently at plug base not by wires.
Next step is to remove screen. there are 2 main bolts that hold the unit in.
The next steps depend on what radio system is in there. I have x line. my radio panel pops off, then I can remove the upper ac panel.
Once those are removed There are 2 screws for the radio. Maybe 4, don't recall. Radio then slides out. unclup the connector, move the green optical cables if you have them.
Harness plugs in between, be sure to lock in slowly. Again depending on your system and the harness.
Do you have the additional speaker?
      01-31-2020, 10:21 AM   #3
jjrolls
Drives: BMW X1
boom! got it! thanks for your help!!
      02-01-2020, 01:20 PM   #4
DarthBeardy
DarthBeardy's Avatar
Drives: M3, X1, 128i, M2
If you have the in dash 6 disc changer: you’re in for a fun time.
Just installed the latest model in mine.
Works great once you get it all setup. A few quirks with the Android side, but I got it for CarPlay + reverse camera.
View post on imgur.com
      02-01-2020, 10:52 PM   #5
proteus290
proteus290's Avatar
Drives: 2014 BMW X1 35I Ultimate
Android 10 Auto soon Avin nav upgrade
What kind of options did u order with this ? seems u can go overboard with the options
has controller nav rear view cam allready, with in dash screen, screen is all dull and smudged out
i have a speaker above the dash ultimate package
has rear cam, looks like a front cam also it does not work? i can a lense by the rear view mirror
been wanting to order this nav upgrade, avin said new version head unit & android 10 comes out in feb.
      02-21-2020, 10:43 AM   #6
jjrolls
Drives: BMW X1
The lens by the rear view mirror is for automatic high beams
      02-21-2020, 10:49 AM   #7
proteus290
proteus290's Avatar
Always was wondering what that lense by mirror did i noticed and had no idea?
proteus290
      03-21-2020, 04:27 PM   #8
BMWX1-35i
2015 X1 35i XDrive with NAV
BMWX1-35i's Avatar
Drives: 2015 X1 35i
Love it, I have a NAV system and I'm looking for something to add on so I can use CarPlay.
2015 X1 35i XDrive
Ultimate, NAV & Cold Weather Package
MHD, FTP Motorsports Charge Pipe, Drop in K&N
