      05-15-2014, 10:45 PM   #1
c98928
Drives: F30 320i
BMS tune placement
I'm about to install a BMS stage 1 tune on my X1, wondering where to place the control box.
Anyone who installed a BMS tune (be it stage 1 or JB4) please tell me where do you place the control box and, if possible, show a picture.
Thanks in advance.
      05-16-2014, 06:30 AM   #2
Randy7fx
Drives: 2014 X1
Are you following the directions that are on the PDF from the burger site? There are pictures in it with clear directions.
      05-16-2014, 12:05 PM   #3
c98928
Drives: F30 320i
Actually I did, I have made myself pretty familiar with the install.
The problem is, the instruction PDF they provides is for F30, which has a significant different engine bay. I can't place the control at the top right hand corner under some rubber seal as I could have F30.
So I really need advice on this, where to place the control box to keep it secured, clean and try in E84's engine bay.
Any advice will be appreciated.
      05-16-2014, 03:41 PM   #4
cwickberg
Drives: X1 35i MSport Ultimate,
There are separate instructions for E9X series cars... If i remember, they refer you to the N54 video or instructions...Typically install your box where the ECM is
      05-17-2014, 04:20 AM   #5
c98928
Drives: F30 320i
Thanks man. I looked up the E series N55 instruction and it hinted a good spot placing the control box.
      05-17-2014, 01:54 PM   #6
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
Drives: 2020 Tesla 3 LR AWD
2013 BMW X1  [10.00]
If it's similar to the N55 135 JB4 install, I taped some foam to one side of the JB4 with painters tape. Then I put the JB4 into the ECU box. The foam kept the JB4 from bouncing around and the painters tape was easy to remove.
