      12-30-2013, 08:48 PM   #1
halfmoonclip
Drives: X1 28i
Valve clatter at low revs?
Thought I heard a little valve clatter or pinging at low revs under load this evening; it is relatively cold outside (20*) tho' the engine was fully warmed up.
I've seen some other 'Diesel' references here; is a little clatter normal?
Thnx,
Moon
      12-30-2013, 10:22 PM   #2
Red Bread
Drives: Smog machines
More than likely it's just the high pressure fuel pump.
      12-31-2013, 07:13 AM   #3
elfhearse
CW5
elfhearse's Avatar
Drives: 14 x28iS/10 e91M/00 Z3MC
2014 BMW x28i  [0.00]
2010 328iT  [0.00]
Drive mode ? I notice the engine RPM is very low, 1200-1500RPM when motoring along in D, causes engine to lug & clatter a bit. (city/rural driving)
I only use D when I'm out on the interstate where its a constant higher speed.
CURRENT:
10 328iT ZMP-6spd, 00 Z3 MCoupe, 76 2002 stg.2 5 speed
PAST: 96 318ti Cali, 03 325Ci, 00 Z3 M Roadster, 99 Z3 2.8 Coupe, 14 X128i M-Sport14 Z4 28i Sport 6-spd
      12-31-2013, 09:10 AM   #4
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
yep, I figured it was normal for a DI engine
      12-31-2013, 09:12 AM   #5
danielj
Drives: 2018 x2
Agreed, it's typical for DI's.
      12-31-2013, 11:37 AM   #6
halfmoonclip
Drives: X1 28i
True that...I may try using 'sport' when lugging around town. OTOH, if it is causing no real damage (tho' the damned car is so smooth the rest of the time...), I may just ignore it.
Moon
      01-02-2014, 01:16 PM   #7
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Moon
Don't worry, that's what the warranty is for...
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD)
2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD)
      01-02-2014, 02:15 PM   #8
halfmoonclip
Drives: X1 28i
Yeah, I know, but it seems to be bad form to bend a valve stem....
Moon
