      01-10-2014, 05:49 PM   #1
johninjax
Drives: 2014 X128i LeMans Blue M Sport
Adding gauge cluster
To those of us that do not have idrive I wonder if anyone makes a cluster that would fit in that space. Perhaps temp, boost & ammeter. Does anyone know if this is available?
      01-10-2014, 06:21 PM   #2
MazdaFan
Drives: 2014 X1 xDrive 28i
There is a fugly navigation unit that fits the space, but needs tearing up the entire dash and center console.
But I saw someone retrofitted a Garmin and it was pretty neat. Search for "Garmin 7" nav installed in dash".
      01-10-2014, 08:51 PM   #3
1fastscooter
1fastscooter's Avatar
Drives: X1 Msport 28i LeMans Blue
I use the bullydog OBD plug in and run the cable up to the display on the right side of my steering wheel.
I display 4 different values; I normally use boost, temp and MPG. It can show in digital on the left and larger on the right is a analog or graph display.
I bought on ebay for 120 used, but they have a website you could check out.
Oh, it is the one for monitoring only not for Diesel. and size is small.
