      08-12-2020, 12:56 PM   #1
surfsup613
surfsup613's Avatar
Drives: 2015 X1 sDrive28i
Engine Fuse Locations?
Hi everyone, I'm having trouble locating the engine management fuses for our E84 X1's. I threw a P0030 code yesterday, heater circuit B1S1 O2 sensor low voltage. Seems like a short circuit or blown fuse for the O2 sensor heater is the first thing to check.
I know they SHOULD be in the white box compartment, up near the pass side firewall/windshield. In fact, from following a DIY for an E90 fuse box location, everything on the outside appears the same to any E9x car: youtube.com/watch?v=Hy9lbVs_iPc&vl=en
However, once inside, the E84 X1 has a different wiring and there is no obvious spot for the engine fuses shown in that E90 video. I see some random fuses, but not sure what is what.
Does anyone know of a diagram that identifies the engine fuses specifically on an X1? Seems like there is not much info for this online
Thanks for any help!!
