      01-09-2014, 03:56 PM   #1
Mojo_Mike
Mojo_Mike's Avatar
Drives: 2014 S Drive 2.8i
Why does the 428 accelerate so faster than the sDrive2.8?
Saw on Edmunds - http://www.edmunds.com/bmw/4-series/...oad-test1.html - an instrumented test of the 428 / 8-speed auto where they were getting 0-60 times of 5.4 seconds. Car & Driver's current issue has similar results.
Wondering why the X1 sDrive 2.8 doesn't match this performance as from what I can tell they have the same engine and the transmissions (identical ratios per the BMW website). The difference in weight is negligible (3470 lbs. for the 428 and 3527 for the X1 - again, per the BMW website).
      01-09-2014, 04:38 PM   #2
MazdaFan
Drives: 2014 X1 xDrive 28i
The official BMW numbers are 5.7 vs 6.2, so they are actually close. The weight is still a factor. The moon roof is standard on 428 and optional on X1. Most X1 that magazines test have moonroof, thats another 80 to 100 lbs. Other than that it could be tire traction (e.g. summer vs. all season) or final drive ratio.
Note: They have the same gearing, so it is the weight and potentially different tires on 428.
      01-09-2014, 05:49 PM   #3
Sackman1886
Drives: 2014 X1 sDrive 28i
Possibly suspension difference? Technically the X1 being the SAV, does it have "softer" suspension? I'm just throwing it out there - I've noticed it DOES have some body roll in it during hard turns. I'm assuming more roll than that of the 3 or 4 series.
      01-09-2014, 06:12 PM   #4
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
Aerodynamics might play into the #s as well (more so at higher speeds for sure). 428i is rated at .28 Cd and the X1 at .32 Cd. Not a huge difference, but once you add that to the all season tires, perhaps throttle mapping differences, transmission programming differences, air intake differences, etc....you might get yourself up to that .5 second difference.
Most places I've read though put the sDrive28i at 6 seconds flat to 60. So a bit better than BMW claims.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
      01-09-2014, 11:37 PM   #5
Twix
Twix's Avatar
Drives: 2011 e91
I've read mags testing a loaded X128i xdrive and achieve 0-60 times of 6 flat. That's not a lot slower than the 428i. Also, what rear end gear does each use? The rear gear makes a ridiculous difference in acceleration.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      01-10-2014, 10:01 AM   #6
Black Flagged
Black Flagged's Avatar
Drives: M2C
aerodynamics plays the biggest effect, with height of the F32 vs. the height of the E84. the 428 probably has a different tune also, to help with the weight of the F32 vs. the E84
      01-10-2014, 10:05 AM   #7
Red Bread
Drives: Smog machines
I could see aerodynamics and/or ride height making a difference in the 1/4 mile, but not 0-60. A barn should be only just a little slower than an SR-71 to 60 if they both have the same power to weight (and if the barn has wheels, of course).
I'd guess it all has to do with tires, has someone compared an M Sport X1 28i sDrive to a 428i with similar tires?
      01-10-2014, 06:04 PM   #8
2014bmwx1
Drives: 2014 bmw x1
probably marketing to justify the higher sticker price.
      01-11-2014, 10:10 AM   #9
Mojo_Mike
Mojo_Mike's Avatar
The 428 tested had the M Sport Package, so it would have summer performance rear tires of 255/40-18 vs. the base all-season 225/45-17 tires on sDrive2.8. Maybe the 428 just hooks really well whereas the sDrive2.8 loses time as the traction control system curtails power to combat wheelspin?
      01-11-2014, 01:24 PM   #10
Naambezet
Netherlands
11
Drives: BMW X1 sDrive 20i
Who would launch a car with TC on?
And why do people use those mediocre all season tyres?
