      01-22-2013, 03:39 PM   #1
manicm
Drives: X1 sDrive18i
Calling runflat experts
Ok, it finally happened, nail got in my tyre, had it repaired at a tyre store (after filling up air at a fuel station and driving for a further 15km).
Indicator hasn't lit up yet, however should I still replace or continue? Any risk of damaging my rim and/or suspension?
Went to my BMW dealer and he suggested I drive for a few days to see if indicator lights up again, surprisingly he didn't try to convince me to buy new tyres, even told me some customers drove repaired tyres till they replaced them after normal wear.
Still, what do you experts think I should do?
      01-22-2013, 04:32 PM   #2
Bill B.
Bill B.'s Avatar
Drives: '18 M2, '13 X135i '15 S1000R
Depending on how long you drove it while flat, there might be damage to the sidewall reinforcement (that's what the manufacturer and what BMW would say when you would ask them to repair a run-flat).
If you didn't drive very far while flat, and had the tire properly patched from the inside(not just plugged from the outside), then if I were you, I wouldn't worry about it.
      01-22-2013, 05:43 PM   #3
Lucky13
Lucky13
I got a nail in my run flats on a new Mini Clubman S, got the hole patched and put 18,000 miles on the tire. I've had several nail holes patched with no issues but never drove any of them with really low pressure. I'm thinking if you drive and still have over 20 lbs of pressure you probably are ok to drive it a few miles without really doing any damage to the sidewalls.
      01-23-2013, 01:58 AM   #4
nospam
Drives: 2015 Alpina B6; 430i; X5 40e
If properly repaired, you have nothing to worry about. Usually, shops not equipped to repair run-flats won't touch them. I've had them repaired at America's Tire without further issues.
The BMW dealers here don't repair runflats. They try and sell you the tire and wheel warranty plan up front then punish you if you don't get it by selling you new tires at inflated prices if anything goes wrong.
      01-23-2013, 06:49 AM   #5
danintas
Australia
11
Drives: 2015 BMW X3 30d Xline
I had one of my Goodyear Efficientgrips repaired just a few week after I got the car, and it's still going strong after almost 40,000 kms!
I think tread punctures can be repaired, but sidewall intrusions are more serious?
      01-23-2013, 09:37 AM   #6
nospam
Sidewall intrusions on any tire are unrepairable.
Past: E36 325i, E39 540i, F46 323i (AA tuned), E82 3.0NA, E84/F30 N20 BMS Stage 1, E70 X5 N55, F06 N55
      01-23-2013, 01:05 PM   #7
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
Except for on old cars with an inner tube.
      01-23-2013, 02:11 PM   #8
nospam
You just took me back to my childhood...floating on inner tubes in the pool. Does that make us country?
      01-23-2013, 03:34 PM   #9
manicm
Thanks guys, luckily the nail was near the middle of the tyre, well away from the sidewall. The tyre dealer also didn't suspect any damage on the tyre - and he had the Pirellis in stock if he really wanted to make a buck. I'll see how it goes.
      01-23-2013, 05:16 PM   #10
Grovsnus
Flight Lieutenant ≛
You had a pool? We had to lug the tractor inner tube up forest paths for forty minutes to get to the ice cold lake!
Well worth it, because that's where the girls were.
(Waiting for the guy from NM to say "You had a LAKE?")
