      02-13-2018, 10:24 AM   #1
kiloTHREE
Drives: '13 xDrive28i
No HVAC Fan, but Defrost Works
Whoa, ran into a weird one coming home from the airport last week.
The temp control was set to auto 74F. The fan never rampped up like it does once the engine is warm.
In fact, even manually setting vent/feet and the fan selector did nothing.
However, I could use the front defrost button on the far right side and that would kick on the fan full bore and get me some heat on the way home.
My car regularly sits at the airport on weekdays so -20 to 0 F degree temps are nothing new.
Took it home, checked a bunch of fuses, ran for codes, nothing out of the ordinary.
Fired it up the next morning and everything is business as usual.:
      02-15-2018, 03:30 PM   #2
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
Lucky you, good that it was a self-repair issue
      02-19-2018, 07:12 AM   #3
Portly
Drives: X1 XDrive28i, M2
Your battery was low. I've had the same issue during cold weather / short trip situations. Once the battery gets charged back up again, the ECU will re-enable higher fan speeds. (Don't ask me why the alternator doesn't just charge at a higher rate...)
      02-19-2018, 07:36 AM   #4
kiloTHREE
That would make sense, odd as it is. That was one of the longest and coldest lengths I've ever let my car sit.
      02-19-2018, 07:06 PM   #5
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
Had this happen to me too. Sadly when I was running just the defrost setting the windshield cracked. Took a few drives to reset the hvac controls but all back to normal. Pretty dumb that the system does that sort of limp mode. I've never experienced that in any of the other bmw's ive owned.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
