      11-10-2013, 04:39 PM   #1
anelson86
Drives: 2014 X1 xDrive28i
Rattle on start up
When I press my ignition to start up the car, there is a metallic rattling sound. It's kind of hard to describe, but it almost sounds like a piece of foil rattling or something. I haven't been able to pinpoint the location, but it only lasts for about 0.5 sec when the engine first fires up.
My best guess for the sound is the exhaust flapper for the dual pipes fluttering before it seats itself during warm up, but I'm not convinced. Been thinking about taking it in to the dealer, but wanted to check and see first if anyone has heard something similar or knows what the cause may be.
      11-11-2013, 02:56 AM   #2
Naambezet
Netherlands
11
Drives: BMW X1 sDrive 20i
Itīs normal.
      11-11-2013, 08:59 AM   #3
anelson86
Originally Posted by Naambezet View Post
Itīs normal.
Thanks - I figured as much. It seemed far to obvious for them to not notice when they prepped it for delivery.
      11-12-2013, 12:00 PM   #4
txchas
Drives: 2013 X1 Sdrive28i
Yep, took mine to the dealer for the same problem. It is the exhaust valve and normal. I would prefer not to hear it, but it is normal.
      11-13-2013, 12:54 PM   #5
ukrboy
Drives: X1 xdrive28i
Same here. Took it to a dealer - they said that it's normal. They compared it to a brand new X1 they had on the lot and it did the same thing. Oh well, mine only does it when cold.
      11-15-2013, 04:28 PM   #6
BMW_X1_MV
Drives: BMW X1 s28i Mineral Gray
Engine Rattle
I can hear this sound (some foil rattling) even after the engine has run for some time. Was planning to take it to the dealer.. Did you guys see this only during the ignition startup or does it continue to be there when the engine is running idle. When press on the gas, the sound kind of gets lost in the engine sound.
      11-15-2013, 11:15 PM   #7
Twix
Twix's Avatar
Drives: 2011 e91
It's there until the engine gets to operating temp
      11-16-2013, 12:46 PM   #8
Van1
Member
11
Drives: BMW M2C
Same rattle here. Real annoying when I start up and leave the parking garage after work. The reverberation of the enclosed space really exacerbates the sound. Didn't notice it when I first bough the car in February as it was cold and I always had the windows up. It's when it got warmer and I had the windows down that I really noticed. It's probably my biggest gripe about the car.
      11-16-2013, 09:58 PM   #9
Twix
Twix's Avatar
Drives: 2011 e91
If you unplug the valve in the exhaust at the exits, the noise will almost go away. Or at least I've been told
      11-23-2013, 01:15 PM   #10
lvlolvlo
lvlolvlo's Avatar
63
Drives: eeeee nein-tee-two
2007 328i  [0.00]
Do you have a picture of what you're referring to? I can try it out if people are interested.
      05-29-2022, 01:02 PM   #11
milanpraha
Drives: BMW F30
Did it sound like this?
It has been a while since this post, but did it sound like this (turn up the volume)?
https://automationdock.com/x1start/
