      06-05-2014, 06:42 AM   #1
3Bims
Drives: XXX
Tire Pressures
BMW says there should be 35 in front and 41 in back. What happens if you go with 41 all around or 45 all around or 41/39, etc?
      06-05-2014, 07:08 AM   #2
Twix
Twix's Avatar
Drives: 2011 e91
You wear your tires.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      06-05-2014, 07:46 AM   #3
Red Bread
Drives: Smog machines
And you'll get even more understeer.
      06-05-2014, 09:26 AM   #4
3Bims
Drives: XXX
Thank you for the responses. Tirerack has some links that say if you overinflate you get better steering response.
      06-05-2014, 11:15 AM   #5
0w40X1
Drives: 2014 BMW X1 s28i M Sport
And less traction.
HOwever, The tires you have and whether you have staggered or not comes into play.
My staggered 8x18 and 9x18 with P7 performance tires likes maximum 38 front and 42 rear filled cold approx 70 deg f which is what the book says for MSport at over 100 mph.
I tested with heat laser on track, and with 38 psi all around, and that translates to about 44-45 hot all around, but that made car understeer somewhat.
IMO that BMW's PSI sticker on door is accurate while lots of other cars aren't.
My staggered needs 1 to 4 more psi in rears to get closer to neutral.
      06-05-2014, 01:14 PM   #6
3Bims
Drives: XXX
I'm not staggered...have 18s all around. Thanks all for the input.
      06-05-2014, 06:26 PM   #7
BeEmVe
Drives: '14 X1 x28i M-Sport
While I know would you meant I would like to see that.
But yes under filling or over filling tires will cause them to wear prematurely.
      06-07-2014, 10:08 AM   #8
halfmoonclip
Drives: X1 28i
Assuming a less than full load (I suspected that the 41 in the rear was a CYA for that eventuality), I've been running 35 all the way around; the understeer seems less noticeable.
Experiment and see what works.
Moon
      06-14-2014, 05:49 PM   #9
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
18x8.5 all around staggered 235x45 & 265x40 air is 34 f and 36 r. This is around town light loads. Plus 2 pounds highway speeds.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
