      03-12-2013, 03:00 PM   #1
Teutonic
Teutonic's Avatar
X1 Recall - Positive battery cable connection
I am due for an oil change and the dealership told me that I am due for recall for a positive battery cable. The advisor told me that it is not a big deal, it is just the positive terminal, however after searching the Internet I found this:
http://healthycanadians.gc.ca/recall...23157r-eng.php
In my appointment description it says:
The following services have been selected for this appointment:
10 CBS Engine Oil Service
61Z Electrical System Misc(1)
It seems that is not just the positive terminal it is the whole cable and I am not happy with this work (plastic covers removed and so on). Can somebody bring some light in this, eventually someone who had this recall done share with me what was done?
Thank you
      03-12-2013, 05:07 PM   #2
eric9610
Drives: 2020 Telsa Model YLR
every e90 has this recall. It is not a big deal and yes it id the whole cable that they are replacing.
      03-12-2013, 05:23 PM   #3
nospam
Drives: 2015 Alpina B6; 430i; X5 40e
What are you concerned about? I've never had a problem any minor recall work like this.
      03-12-2013, 06:17 PM   #4
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
Also it shows only for the 2012 X1
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      03-12-2013, 07:38 PM   #5
Teutonic
Teutonic's Avatar
Yap, except sometimes they manage to break some litle things so the plastic covers will never stay in place. If they need to run the cable from front to the rear there are few parts that need to be removed and the cable must be installed nice and tight with the rest of them. I have seen butcher work done by some technicians in cases like this. Believe me, I know what I am talking about.
Mine is a 2012 and is one of the first X1 sold in Canada.
      03-13-2013, 04:47 AM   #6
JL350
Australia
20
Drives: 2.0D X4
Mmmm, your call, you could say you don't want it done and pay later when the electrical system has issues and they decline to fix it. If you have concerns about collateral damage speak to the service department nicely about them.
My feeling is you have to trust them to do the work properly and inspect afterwards and get any issues addressed.
If it is a particular dealer that breaks stuff, go somewhere else.
      03-13-2013, 11:02 AM   #7
CIWS
Moon Parasite
CIWS's Avatar
Agreed, but your thread says X1, not 2012 X1 which is the only model the recall applies to.
      03-13-2013, 04:38 PM   #8
loukas135
Drives: BMW X1 xDrive28i M Sport
Just checked today with my dealer. The recall affect only particular 2012 X1 model based on serial number.
Mine wasn't listed so minus one recall
      03-22-2013, 01:12 AM   #9
Teutonic
Teutonic's Avatar
Ok, so I had the positive cable recall done today. ( 61Z Electrical System Misc )
So what they are doing is they are cutting the positive cable from the fuse box (remove the glove box and the fuse box) and they are installing a new 30 cm cable which has a more ferm positive plug at one end (that is the actual problem because the old plug is small and can loose the contact with the fuse box) and connect it with the old cutted cable by clamping them togheter. After that they insulate it and install it back. The operation took 2 hours.
