      09-28-2010, 10:56 PM   #1
leel
Drives: X1
Sunroof noise
Hi,
Has anyone experienced an unbearable noise when they have their sunroof all the way back? It seems the shield does not prevent the noise and might even make it worse?
      10-19-2010, 01:14 PM   #2
Exotic Hadron
X Eins in der Luft
12
Drives: X1
Hmm, nope, mine is with the roof and I used to drive the X1 with it opened and everything was OK. Could it be so that you are driving it with the roof opened while your climate control is active? If so, it will almost definitely create the air beatings.
      10-19-2010, 05:46 PM   #3
mozdal
mozdal's Avatar
Turkey
19
Drives: E84 & F20 & F10
Try opening one of the back door windows a little bit, that will allow the air to flow through and might solve the noise problem.
